Question about HP OfficeJet 6110 All-In-One InkJet Printer
Computer won't recognize 6110 printer when asked to print
Had to put in new harddrive and now the computer does not print on my HP OfficeJet 6110 printer. It recognized the connection of the printer, but can't load the information of the printer. I don't have a disk for the printer, can I download something for the computer from the internet?
    President:
  • 1,901 Answers
Yes. Go to this site:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=79477&lc=en&cc=us&dlc=en&submit.y=12&submit.x=9&lang=en&cc=us
Select your operating system and download the software you need/want.
You can also order a CD, if you like.
Posted on Oct 15, 2008
Will my hp officejet 6110 work on chromebook
Yes your hp office jet 6110 works on chrome book by following the below methods:
Method 1: Check system requirements
• Chrome book connected to the network with an active Internet connection.
• Create Google account in the latest version of chrome browser.
• The printer hardware is set up and connected Chrome book with a USB cable or wireless network.
USB connection: Make sure the cable is securely connected to the printer and to a working USB port on your Chrome book or computer.
Wireless network connection: On the printer, make sure the wireless signal is turned on and the printer is connected to your network. Make sure the printer is connected to the same network the Chrome book or computer connects to.
Method 2: Install HP Print for Chrome
1. Open the Chrome browser, and then go to the HP Print for Chrome
2. Click ADD TO CHROME.
A confirmation message displays. Adding the HP Print for Chrome app
3. In the Add "HP Print for Chrome" window, click Add app to confirm the new app.
Feb 01, 2017 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 Officejet all-in-one will not print from the glass top. It will make prints coming from the computer after I press "enter" from message "paper jam". I also can fax. Please help.
You will need to open the top and look inside where the paper travels through and attempt to free any paper pieces that have gotten stuck in the pathway. You probably have a bad board in your control panel, since you are able to print from the computer.
Feb 20, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Officejet 6110- do display/needs attention light on continuously
try this
turn on/off, unplug, plug in, should reset configs. might have to do this a coupe of times
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
hope this helps and good luck
Apr 28, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 all-in-one won't print despite new cartridges
make sure that the housing that holds the cartridges are clean at the contacts, this can be done with the machine turned off and unplugged, clean the contacts with warm water and a damp cotton bud not wet and then dry it with a paper towel.
make sure everything is dry before turning the printer back on, if this doesnt work then it needs a service.
Nov 28, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning problems w/officejet 6110
Remove the HP software then reinstall the software from HP's site
Sep 24, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Officejet 6110 all in one - printing problem with Mac Os X 10.5
I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
Regards
Rafique
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer wont print HP OFFICEJET 6110 all-in-one
1-if you are in any application, word, windows etc... click on
File
Print
Is the printer there hp 6110 ( if not reinstall driver)
does it have a checmark next to it? no, then right click
go to properties
set as default
put your mouse over printer, does it say ready? no, check connection or change cable.
Good luck
Nov 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 Prints very slow then aborts about 1/3rd way through print
I identified this issue with my Officejet 6110xi All-in-One as firmware corruption. Attempting to install the supplied firmware update gave the error that "no hp device connected to the computer would benefit from it at this time." Attempted to power down the printer using #9 keystroke and got "FULL RESET" message, but problem of extremely slow printing and erratic behavior of the print heads persisted. I solved the problem by putting the printer outside in cold weather for two (2) days. This frequently resets firmwares with software corruption back to their embedded EEPROM state. Hooked the printer back up and worked fine. If cold weather is not available you could try other creative methods of cooling the device, just use a plastic bag and with ideally some drying packets thrown in to prevent excessive moisture buildup in the cold environment. The colder it is the faster the firmware resets.
-Paul Ronco, Computer Technician
www.paulronco.com
Oct 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
44 people viewed this question
Ben Johnson
