Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Poulon 2375 18" Wild Thing NO SPARK
Removed covers and flywheel. Expected dirty points under flywheel. NO POINTS THERE. Electronic Ignition module has Secondary Spark plug cable and terminals for 2 wires. Yellow wire is for shorting the spark and go to the ON/OFF switch. Cannot see where the BLACK wire goes. I suspect it is the trigger to where the points should be. Before spending $26 for a new ignition module would like to know if the black wire is the root of my problems. Does this engine have POINTS? If i do have to replace the Electronic Ignition Module what is the gap to the closest part of the flywheel where the magnets are. It appears to be about .040. or a little more. Is it POSSIBLE the magnets in the flywheel are weak. I have never had to replace a flywheel in 40 years.
Thanks Hank
    Problem Solver:
  • 9 Answers
Your engine doesn't have points. I suspect the black wire is a ground for the ignition. You can check this by taking a very small chunk out of the insulation and then using an ohmmeter to check and see if it is indeed grounded. If it is you probably need an ignition coil assy. It is triggered from the flywheel itself. Make sure your switch is ok and the wires going to it are ok.
Posted on Oct 26, 2008
Won't start but is getting plenty of fuel. Also has a new spark plug.
Test the spark plug (gapped at 0.020") for blue, snappy spark. If weak or nothing, remove the left side cover to expose the flywheel and ignition module. Turn the flywheel until the magnets are under the poles of the module, insert a thin business card into the pole gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and turn the flywheel somewhat to release the card, then turn the flywheel one full turn to make sure the gaps don't close up. Remove the ignition switch wire from the module body, and try for spark again. If nothing, replace the module using the above procedure. If you did get spark, replace the ignition switch wire and try again--if nothing now, look for a short circuit to ground in the wire or the ignition switch. If you got a good spark in the first test, pour a little fuel mix into the plug hole and try for start--if pops several times, you have fuel delivery problems. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the primer bulb fills with fuel when pumped several times. Does the engine seem to have good compression? Hope some of this helps!
Dec 11, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Saw will idle but when you give it gas it cuts off
Check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Check the spark plug for blue, snappy spark. If weak looking, try a fresh plug gapped 0.020". If still weak looking, remove the left engine cover to expose the flywheel and ignition module. Turn the flywheel until the magnets are under the ignition module, insert a thin business card into the pole gaps, loosen the module screws, and allow the module to contact the magnets. Tighten the screws, then turn the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the pole gaps don't close up further. Hope this helps!
Dec 02, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
CS346 no spark, replaced ignition coil and it did not help, have checked switch and disconnected it. Ideas?
Did you try a fresh spark plug gapped at 0.020"? The ignition module needs to be very close to the flywheel magnets to get good spark. Turn the flywheel magnets just under the module, insert a thin business card into the gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to release the card. Rotate the flywheel one full turn to make sure the gaps don't close up at any point. Unless this is an older saw with points and condenser, it should now have good spark. Hope this helps!
Nov 17, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Poulan 2375le chain saw. just replaced primer bulb, gas lines and diaphram. also has new gas and spark plug. will fire up but wont stay cranked especially when I mash the throttle. please help..
Check the fuel filter, air cleaner and muffler for plugging. Be sure the fuel and oil mix is thoroughly shaken just before filling the tank each time to prevent oil starvation. Set the plug gap to 0.020" and test the spark for being blue and snappy. If weak looking, remove the left side engine cover to expose the flywheel and ignition module. Turn the flywheel so that the magnets are just under the module poles, insert a thin business card into the gaps, loosen the module screws to allow the poles to contact the magnets. Tighten the screws, turn the flywheel somewhat to remove the card, then turn the flywheel one full turn to make sure the gaps don't close up further. Replace the cover and retest spark--if ok, try for start. Hope this helps!
Nov 11, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulon chain saw model 2175 no spark. What to check?
Remove the starter assembly and left side cover to expose the flywheel and ignition module after trying a new spark plug gapped at 0.020". Remove the ignition switch wire from the module and try for spark again--if still nothing, use a thin business card for a gap gauge between the flywheel magnets and the module poles. Loosen the mounting screws, let the module contact the magnets through the card, then tighten the screws. Try for spark again--if still nothing, replace the module. Use the above procedure to install the new part. Hope this helps!
Aug 05, 2010 | Poulan Garden
No spark
Assuming that you have tried a new plug with no results, remove the flywheel side cover to expose the flywheel and ignition module. Remove the ignition switch wire from the module and try for spark again. If nothing, replace the module. Use a thin business card for the pole gap gauge--place the card between the flywheel magnets and the module, then allow the two parts to stick together. Tighten the screws, then rotate the flywheel to remove the card. Turn the flywheel one full turn and make sure the gap doesn't close up any further. At this point, you should have spark. Set the plug gap at 0.020". Hope this helps!
Jun 27, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Installed 2 new starting coils, but still won't fire. Get only little spark. Has new spark plug. What else could be wrong?
Use a thin business card for a module gap gauge. Rotate the flywheel magnets under the ignition module, insert the card into the gap, loosen the module screws and allow it to contact the magnets. Tighten the screws again, and rotate the flywheel to remove the card. Make sure the plug has 0.020" gap. You should have plenty of fire. If not, the flywheel magnets may have gotten weak, or the ignition switch is partially grounded out. Hope this helps!
Jun 23, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Timing adjustment for Poulan 18'' Wild Thing P4018WT
Ignition timing is fixed by use of a flywheel 'key' that locks the flywheel to the crankshaft. If the key happens to shear, then the timing will be incorrect. Expose the flywheel and check the ignition module gap to the flywheel magnets by using a thin business card for a gauge. Turn the magnets under the module, insert the card, and loosen the module mounting screws. Allow the module to stick to the magnets, then tighten the screws. Rotate the flywheel to remove the card, then turn it one complete revolution to make sure the gap doesn't close up any further. Remove the spark plug and check for snappy, blue spark when the engine is pulled through. If no spark, remove the ignition switch wire from the ignition module, the retry for spark. If still nothing, replace the ignition module itself. If pulling the wire gives spark, then check the ignition switch and the wire for grounding at some point. Hope this helps!
Jun 15, 2010 | Garden
What is the gap for the ignition module on a poulan wild thing chain saw?
A thin business card is just right for setting the gap. Turn the magnets to be under the module poles, loosen the module screws and allow it to stick to the magnets. Tighten the screws, rotate the magnets away and remove the card. If the module is good it should make a snappy blue spark with a new plug. If rotating the flywheel through one revolution causes any core rubbing, the crankshaft may be bent or the flywheel may not be fully seated on the crank shaft. Don't run the engine until this problem is repaired. Hope this helps!
May 10, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Saw won't start
Remove the spark plug and check for a snappy, blue spark. If nothing or very weak, try another plug. If still nothing, remove the switch wire from the ignition module. If still nothing, replace the ignition module. Use a thin business card to set the gap and have the magnets under the module poles. You should have spark at this point. If still won't fire, but has spark, try spraying some starting fluid into the plug hole, install the plug, and try to start. If you get a couple of pops, then check the fuel lines, fuel filter, and make sure the screws are tight on the carburetor. If still won't run, you may need to clean and re-kit the carburetor. Make sure the air cleaner and muffler are not plugged. Hope some of this helps!
Apr 09, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
299 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
