HP Compaq Business Notebook NX9010 Logo
Posted on Oct 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Laptop HP NX9010 will not boot, Will go to bios, powers off after that.
Hope you can help!!
I have a NX9010 that was given to me. It has a P4 3.06, I have 333mhz(256 in each slot)I tryed 266mhz.same response. I tryed 1 stick in each slot and reverse, same response The laptop will power on and show boot screen with the options of ESC(for boot opt) ,F2(Bios), F12(Lan boot). It will go to bios just fine,allows to save and exit, it will go to boot menu(all choices are there(cd,floppy,HD,Lan) pick one and it shuts off. Exit bios and it goes through the boot menu again and then shuts off. power up and do nothing it shuts off right after boot screen(esc,f2,f12). I just do not know what to do, thought maybe someone had some suggestions.
  • mtnkid Oct 15, 2008
    The bios does recognize the hardrive. I have run the hard drive test through the bios and it passes clean. I set the boot order to floppy, cd, and then HD. It saves reboots and then shuts down. Thanks for the response, any more suggestions?
  • Anonymous Nov 20, 2011
    i wana knw the same how can fix it
carpenter123
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Mar 05, 2009
carpenter123
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
1540
Points
10
It still sound like the hardrive,you can download a live cd of linix and try to see if it will run on linix,if so try reformatting the hardrive and reinstall windows,if you can get a copy of windows 98 and install that first 98 has a tendency to repair bad sectors of a harddrive,I have had many laptop drives not take xp untill I put 98 first.
  • carpenter123 Mar 05, 2009
    also I have had one that the memery was bad and did just the same thing,swapped memery and it was fine.if the 2 sticks you treid came from that laptop find another to try.
Anonymous
Level 3:
An expert that gotĀ 10 achievements.
Genius:
  • Master 1,913 Answers
  • Posted on Oct 15, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1913
Questions
5
Helped
687525
Points
5322
U must have to detect your hard disk.
check u detect your hdisk in bios settings.
then also try to boot option and select hdd .
Laptop stopped booting
It is dead... give it a decent burial... win 98 is not functional anymore...
How do i format my hp compacq n*9010
You have to format a hard drive with a third party disk unless its a usb data drive
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys navigate to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
hope it helps
When start my laptop, get an error msg. "Grab loading 1.5, please wait.. grab loading error 17. and i can not boot from cd / dvd too..in HP nx9010. Plz help me.
This grub loading error 17 means that the file system type could not be recognised you should be able to boot from a cd make sure the cd or dvd drive is enabled as the first boot device in bios
I hope this helps
Andrew A
I forgot my login password for my Compaq nx9010, is there anyway for me to be able to log in?
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
Hp conpaque nx9100 is not booting its HDD LED siply glows on switching on
try resetting the bios of your laptop by taking out the bios battery from ur laptop. if it doesnt work take out the HDD and insert again.
2answers
Laptop switches off immediately after powering on
Try powering it on with the battery removed. I have seen some laptops where if you have a bad battery it will cause boot issues.
How can i clear bios from hp compaq nx 9010 notebook
Are you wanting to clear thr BIOS password? IF so the only way to do it on a laptop is to pull the CMOS battery out. Then boot the computer up to BIOS and it should be cleared, then just reinstall the battery.
Setup problem
when u say setup do u mean bios setup or windows setup.if windows setup u have os disk in cd.if not , in bios choose save and exit if no joy have hd problem maybe need to reinstall os.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
