Question about Ovens
Coronado brand stove, oven not working
I have an old Coronado brand stove and the oven is not working at all. We just moved it into a new house and now it will not work. I can not seem to find any info on this old of brand. The stove top works fine. There are timers up on top that are for start time and stop time and a clock.
5 Suggested Answers
  • 10 Answers
SOURCE: burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Posted on Nov 19, 2007
  • 8 Answers
SOURCE: stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Posted on Oct 11, 2008
EllaWatson25
  • 725 Answers
SOURCE: I too have an Admiral stove and the top 4 burners
If you will contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service with your model number, we can attempt to diagnose this problem for you.
We look forward to getting you cooking again.
Posted on Nov 08, 2009
  • 250 Answers
SOURCE: Moved to house with a Simpson Neptune oven (analogue clock)
Try this. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Posted on Jul 31, 2010
I have kenmore c880 model stove , both oven and stove are not heating up after shifting to new house...any tips to get it resolved? Only oven light is working.
Make sure there is 220 volts at the wall socket where you plug the oven into. A faulty circuit breaker in the power panel on your house will only let 110 volts get to the oven so the lights and timers will work but not the heating elements.
Sep 09, 2016 | Kenmore Ovens
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
I have recently moved into a new house and can't get the oven to work. I was hoping to get a manual for the wall oven and see if this information will solve my problem. It is a 1993 model EVBS3193...
So you have moved to a new house. I am assumeing that the Oven worked fine at the old house. I am also assumeing that you have plugged the Oven into your new house and that is when you noticed that it was not working.
If this is the case then the problem may be that the Breaker in the Electrical Sevice Panel of the new house is off. You need to reset the breaker and the Oven should then work.
Jun 12, 2011 | Ovens
Lost manual
Hi,you can download the manual for your unit for free at;www.manualsonline.com or www.manualnguide.com.
Thanks and take care
Apr 19, 2010 | Stoves Premier 720DCa Dual Double Oven
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
Feb 22, 2009 | Stoves 720EF Electric Double Oven
Small electric kenmore oven
sounds like youve shaken or loosened one of the power leads into the oven, check the circuit breakers first, make sure they have not tripped, if not turn off hte breaker and remove the back panel of the stove youre only getting half power to the unit doesnt sound like anything magor at all
Apr 29, 2008 | Ovens
Ovens Logo
731 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
