Question about Brother MFC 9700 All-In-One Laser Printer
Making copys when printing copy from the computer they are clear when making copys maunal they are not clear
    Genius:
  • 1,268 Answers
You need to update the driver of your printer. First, try to reinstall everything like the software and driver that came with your device. If that doesn't work, updating the driver will fix your problem.
Posted on Oct 15, 2008
How can I get my Brother printer 795 CW to make copies. I have already replaced all ink cartridges.
Not clear what is your problem. Are you trying to print from a computer or trying to make a photocopy of a hard copy?
Feb 07, 2013 | Office Equipment & Supplies
Type your problem for a solution... my lexmark is not printing or copying.
If you're not able to do a simply copy using the Copy button on the printer operator panel, please try the steps below to reset your printer:
  1. Disconnect the printer from your computer.
  2. Remove the sheets of paper from the feeder.
  3. Open the printer cover and remove the cartridges.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, re-insert the cartridges.
  7. Load some paper.
  8. Try to make a copy again using the Copy button on the printer.
  9. If copying is working fine, reconnect the printer to your computer.
  10. Before trying to send a new print job, make sure the print queue is clear. Then try to print a document from your computer.
Should you still need assistance, please leave a comment to my response and I'll get back to you. Should this resolves your problem, your rating will be greatly appreciated.
Oct 02, 2011 | Lexmark X1240 All-In-One InkJet Printer
The printer is streaking black streaks through the copies. What can I do to fix this problem?
If printing from your computer prints clear pages with no streaks, then the problem could be due to some dirt on the scanner bed. Grab a moistened soft cloth and gently wipe the scanner glass to clean it. Try to make a copy again.
Jul 12, 2011 | Lexmark X2600 InkJet Printer
What button to press to copy a document ?
If you are putting a document into the printer and want to make a copy of it, press the key that says "copy" on the printers keyboard. Then choose the number of copies you want to make and press the "ok" or "enter" key on the keyboard of the printer.
If the document you wish to make a copy of is located in your computer and you dont have a copy of it to place in your printer - then you need to print the document. Not copy the document. Copy means make another one. You can't copy something that you dont have in your hands. Understand? To print a document that you dont have in your hands, find it on your computer. When you find the document you want to print on the computer, click on "file" in the upper left side corner of your computer screen and slide down to "print" and click on it. Then click on "ok" on the next screen to start printing your document.
If there is no "file" command in the upper left corner of your computer screen when you have the document that you want to print open on the computer - try right clicking with the button on the right side of your mouse in the center of the document and find the "print" command on the drop down list and click on it. Then click on "ok" on the next screen and this will start the printing of your document.
Hope this helps? Good luck!
Jul 07, 2011 | Office Equipment & Supplies
We have an HP Officejet Pro L7580, we never use the scanner or fax. Only used for making copies. When I attempt to make a copy, there is an alert sound, then it says scanner failure on both the computer...
u should be good even if ur not using the scanner or fax. in the printer settings check if ur actually mean printing it from the computer or scanning a document and printing it out through it. this needs to cleared out. btw check if ur using the correct driver. i prefer not to use the one that is automatically installed in windows. USE THE ONE THAT CAME WITH IT OR DOWNLOAD FROM HP.
May 05, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Sharp al1631 copier doesn't work after replacing new drum
Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
Hit clear a few times and there you go!
Here it is in a line:
"C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
Good Luck
Oct 21, 2009 | Sharp AL 1631 Copier
My hp psc 2410 photosmart printer will not print - only copy
Check to make sure your PSC 2410 is in fact the default printer. If it is, make sure your cable is firmly plugged in to your printer and CPU. Clear the print queue. Turn off and restart printer. I have found that your problem is basically a communication problem between the computer and printer. Also check www.hp.com. Good luck.
Feb 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
Xerox xe80 workcentre prints almost black copies
Hello sir; Just replace drum cartridge, it will take care your problem. GOOD LUCK!
Oct 31, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Sep 05, 2008 | Brother MFC-465CN InkJet Printer
Brother MFC 9700 All-In-One Laser Printer Logo
52 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
