Question about Dishwashers
Dishwasher quietpower3 it is a liquid soap that we have always used. we have tried to cut the soap usage in half, and there is still build up of soap on the dishes. we have city water so good water pressure, and i ran 3/4 in. copper all the way through the house it is reduced to 1/2 in. 2 feet before the dishwasher
    An expert whose answer gotĀ voted for 100 times.
  • 171 Answers
Hi again,
Good water pressure and the right soap and still it builds. I have seen this before. It's most likely defective. With a new d/w it's always better to call warranty repair. As soon as you start to take it apart you void the warranty. I suspect they'll end up replacing the unit.
Posted on Oct 15, 2008
Dishwasher suds up and leaks during wash
Suds in a dishwasher usually come from using too much soap or the wrong kind. Soap can build up over times causing problems. First start a cycle.Do not add detergent or any dishes.When it starts washing, pour a cup of vegetable oil directly into the tub. This will cut the existing soap suds. You may need to try this a couple time before the dishwasher will drain. After all suds have been removed, load you dishwasher and start a cycle filling the detergent cup up half way. If it goes through the cycle with no problems, you should be all set. Still have the problem? A rinse aid dispenser that dispenses too much rinse aid will also cause the dishwasher to suds up. You can remove the dispenser from the door, flush it out and reinstall. Make sure you turn the circuit breaker off before taking the door apart. After rinsing it out, do not add rinse aid. Try the dishwasher and see if the problem goes away. I've seen people accidentally put liquid dish detergent in dispensers too. A dishwasher that has suds is apt to leak. Fix your suds issue and you most likely will fix you leak
Dec 27, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Do you use liquid soap?
If you use liquid you should use very little, about 1/3 of the soap cup. Liquid soap will build up inside the dishwasher so to help prevebt it from oversudsing you will want to run a empty load with a coffee cup full of white vinager sitting on the upper rack. This will help flush out what the soap leaves behind.
on Dec 04, 2009 | Dishwashers
Isn't using the soap appropriTely
I would either switch soap and us a liquid soap or fill the reservoir with less soap. A dishwasher does not need to use a lot of soap since it uses very hot water.
Feb 01, 2018 | Frigidaire FPHD2491K Builtin Dishwasher
Dishes not clean, soap not dissolving completly(powerball tabs and cascade gel)
first step would be to cut your soap usage in half. To much soap will cause the problems above.
Jun 10, 2010 | Maytag MDBS561AWS Stainless Steel...
Dishwasher has abundance of suds I have tried 3 different detergents and cut back to less than half recommended any solutions? Suds leak up and over the seal
My guess is that someone used the incorrect soap, and the system has not flushed it out yet. Run without soap, not for dish cleaning, but for dishwasher cleaning... Rinse until no soap, then try again.
Nov 01, 2009 | Dishwashers
Build up in dishwasher
powder works best in d/w. breaks down better in hot water application.
Oct 26, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
Hello chystalsbrr
You said you, filled the rinse dispenser with liquid soap. how do I rinse this out? So I can use the washer without it sudsing up everywhere?
You can try by turning off the breaker in the electric box that feeds the dishwasher for 5 minutes and see if when you turn it back on and the washer resets itself, and the soap door opens.
Or push cancel and then rinse and after it is done and goes to the dry cycle stop it and it should be open.
In the use of liquid soap in both a dishwasher and or washing machine you must use less soap. Half that of powder soap.
Or the suds will roll out of your dishwasher on to your floor. And this is not a malfunction on the dishwashers part. NO bad seal or anything!
In a clothes washer it will destroy the seal and bearing in less than 5 years!
Let me know how it goes!
Please remember to leave a rating
Oct 19, 2008 | Whirlpool Dishwashers
GE Dishwasher
Hi tucker19,
I'm Harvey the Master Plumber.
Your question is: You just purchased a GE Dishwasher from Home Depot...Its a QuietPower3...and after you run it, there is detergent build up on the detergent dispenser lid and residue on dishes...HEAVY RESIDUE...Why????
Are you useing a dry soap? If so, try a liquid. Make sure it says DISHWASHER soap on it. Also, use half as much liquid as the dry. Some new d/w's can be tempermental that way. If it persists then use the warranty.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Oct 13, 2008 | Dishwashers
Water leaking from the door
Could be a number of things. If you are in an area with hard water you could be using too much soap or the wrong soap. The dishwasher could be out of level, or the door seal could need replacing. Dishwashers also need to be cleaned. Soap residue builds over time. Try running the d/w with no dishes or soap, pour 5-6 cups of white vinegar directly into the tub and run a whole cycle. And again watch the soap usage.
Apr 08, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
Top Dishwashers Experts
