Question about E-Machines Computers & Internet
No power i can not get power to my w3080 emachine
    Genius:
  • 1,605 Answers
Make sure the power cord is plugged into a working outlet, and make sure the other end of the power cord is firmly seated in the power supply. also look at the side of the plug, there should be a slide switch label (112V, 240V), make sure the slide switch display 112V. (if you are in USA). otherwise 240V.
if this help you solved the problem. please rate the answer.
thank you
Posted on Oct 15, 2008
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
I am getting a load needed DLLs for kernel message when I boot my computer. I have an older model W3080 eMachines desktop. When I insert the restore CD I can not move the curser to press 2. to reboot. It...
I'm trying to eliminate whether this is a software or hardware issue.
Your Ps2 keyboard may have a faulty key or controller that is stopping you press F2. Uisng a USB keyboard known to be good and with USB enabled in the bios, will at least eliminate a hardware issue.
If as you suspect the restore CD is damaged (Cds last a bit longer then 2 years), I'd "borrow" a copy of a windows install cd and try that
Jan 27, 2011 | E-Machines eMachines Desktop PC
How do I reset my BIOS to the factory settings? I think I have an eMachines W3080.
Tap F2 as soon as computer turns on , then press f9 or load optimised defaults that it then press f10 then save and exit
Jan 26, 2011 | E-Machines eMachines Desktop PC
I have no drivers im trying to rebuild my
this is a 'piece of cake'...just let me know the exact model of your computer ...if it is a brand one..(including the particularities.. if they have more than one choice on devices that equips it ) . also specify the operation system you intend to install and I will provide download links...If you have peripherals like printers...or any other devices installed after (video cards ..sound cards..usb devices..) specify their name also ...and its 90 % sure that I find drivers suitable for them ...After that you just save them on a safe location and use them each time reinstall the computer ..if you need a good Xp windows..genuine ..let me know and I will link you to an image download also..
May 01, 2010 | E-Machines eMachines Desktop PC
I have an emachine W3080 that I unplugged the front panel wiring, power switch, power LED, and floppy LED and dont remember which pins they plug into. Can you help?
their should be some abrevations like pwr led, pwr sw, hdd led by some metal pins in one of the corner of the motherboard
Feb 26, 2010 | Computers & Internet
Have an emachine W3080 3000+. I can make connection through DSL but When I open explorer or Mozilla Firefox the URL comes in at the address but the window is blank. I tried another computer with the same...
I shoulds like you have a corrupted DNS cache or host file on your pc. I have a file on my web server that we use to correct such issues. You can get it at www.ccl-la.com/winsockxpfix.zip download it and unzip it with winrar or pkzip. RUn it on the machine with the problem. It will reset the DNS and hosts file, and renew your ip address. The machine will need to be reset and then the problem should be gone.
Buddy
Corporate Computer
Over 21 years of PC and printer support/repair
Jun 18, 2009 | E-Machines eMachines Desktop PC
W3080
the main problem is the drivers. have you re-installed windows recently? have they ever worked before?
Oct 29, 2008 | E-Machines eMachines Desktop PC
CD-RW drive
From your inforation I suggest replace the CD/RW drive, I would believe it is no longer operational. They are very inexpensive online, and very easy to replace. BPCS
Dec 31, 2007 | E-Machines eMachines Desktop PC
Computers & Internet Logo
66 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
