Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier 8000 weathermaker filter
I can't find the filter so that I can replace it with a clean one
    Scholar:
  • 121 Answers
The filter should be located in the front there should be some kind of tab to pull out the filter.
Posted on Oct 15, 2008
5 Suggested Answers
  • 121 Answers
SOURCE: I need to change the
There is a filter on the bottom of the unit. You will either have to remove the bottom panel in the front. Or thereis a thin acess panel down in the front of the unit.
Posted on Oct 24, 2008
meBNme
  • 334 Answers
SOURCE: Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Posted on Jan 31, 2010
SOURCE: carrier furnace weathermaker 8000
I think the running on power up is just a test mode for a service person.
Posted on Nov 25, 2007
shastalaker7
  • 1515 Answers
SOURCE: Carrier Weathermaker 8000 error code 32
Hi, if its blinking 3 fast and 2 slow and saying the error is the pressure switch, kill the power. Pull the hose loose from the inducer motor to the switch and blow back and forth. You can hear the single pole contact click open and close. Put it back together and try it again. If it continues, check for any leaks in the air lines first, and if not, replace the switch. You would be better off to order one over the Internet.For a temp. fix only, if the switch contacts are welded shut or open, you can bypass this safety by taking a piece of electrical wire with clips on each end, and jump across the 2 wires. Some have 3 just find the 2 that makes it work. Good luck,
Shastalaker7
Posted on Dec 01, 2011
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Carrier weathermaker 8000
The filter should slide out of a built in rack from the side of the furnace by the return inlet. It should have the size on it or you'll have to measure it. It may also be inside the bottom door. Pull the door up and out, the filter will be on one side or the other. Unless you have a special Hepa or electronic filtering system.
Dec 12, 2013 | Heating & Cooling
Carrier 8000 weathermaker 92000 btu
If it works with blower door off sounds like it's not getting enough return. What's the statics? Try an adjustable limit, I think they go to 210. Good Luck!!
Jun 13, 2017 | Carrier Heating & Cooling
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
My A/C (Carrier weathermaker 8000 hybrid) is not cooling properly
set the t-stat low and let it run for 5 minutes , stick a thermometer in the return air closest to the unit as possible until you get a good reading , then stick the thermometer in the cold air supply again closest to the indoor unit as possible let sit until it stops going down in temp.
this is called your temp difference and it should be atleast a 14deg. F difference from in to out. if its lower you have a refrigerant problem, Let me know how it goes.
Phil
Jun 10, 2009 | Heating & Cooling
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
I need to change the filter in my Carrier Weathermaker 8000. WHERE IS THE DOOR?
Oct 24, 2008 | Heating & Cooling
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
1,384 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
