Question about Kicker KX1200.1 Car Audio Amplifier
Kicker KX800.4 Protection light problem
Hi, I have a Kicker KX800.4 that has the power, ground, and remote all hocked to it. I have had this in the vehichle before, it was taken out and placed in another vehichle and now put back in the original. Every time I try to turn the amp on, the protection light comes on. It has never had a prob before and I rechecked all the wiring with a test light. Any ideas on what may be the problem or any test I can run to double check anything. Any help would be appreciated. Thanks!
  • J D
    J D Dec 05, 2008
    Thats the same thing wrong with mine, All my cables are unhooked and it's still not giving me ****. Well au contraire, it's giving me too much ****.... but like you said, only the power, remote and ground, and i have a massive ground and power, and the effing protect light is still on.... fried capacitors, all we need now is some beer and some chicks dancing in skimpy *** clothes and we got a party. Thanks Pbabin!
  • 631 Answers
If the voltage is sufficient on the B+ and remote terminals and the amp goes into protect with no speaker wires or RCAs connected to the amp, it probably has shorted output transistors.
Let me know if you have any other questions.
Posted on Oct 15, 2008
How do I wire a kicker mono amp for my subwoofer to a kicker 4 channel amp that is already hooked up to run the 4 6x8 speakers
you should have an output on the amp running the 4 6/8's connect to kicker inputs hope you got a cap(capacitor)to run this set up and a good wiring kit.if so just run all the power cables to the power block feed the amps,ground them and don't forget the remote wire and you should be fine
Sep 23, 2014 | Car Audio & Video
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
Jul 25, 2011 | Kicker KX500.2 Car Audio Amplifier
I have an 06 kicker zx 1500 monoblock amplifier. The other day i was bumping it pretty hard and it just stopped playing so i stopped and then i stopped to look at the amp and the light was off but the...
Check the impedance of the speaker to be sure that it matches the output of the amp. Common error on this detail can cause the amp to overheat and shutdown/protect.
Jul 23, 2011 | Kicker ZX1500.1 Car Audio Amplifier
I have a "12 kicker
If it is the amplifier that is shutting on and off:
Check to make sure the power and ground wires for the amp are secure, with no fraying, knicks or exposed wire. Check your fuses and connections to make sure everything is correct. Also look at the grounding location. be sure there is exposed metal around the grounding point (paint may cause intermittent power problems). Lastly, the amplifier's remote wire may be improperly secured to the wiring harness. Check the harness for exposed wire grounding out connections.
If the amplifier is continuously on, the subwoofer may be to blame. Check and double check wiring schematics to ensure correct ohms rating.
Feb 28, 2011 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Can kicker 1000x1 amp detect if my speaker is bad and turn itself off?
The Kicker 1000x1 Amplifier does not turn off if their is an Open Line (blown sub) on the Speaker Terminals.
  1. Remove all Speaker Wiring from the Amplifier, leaving the Power, Ground, Remote, and RCA wires plugged in.
  2. If the Amplifier fails to turn on, check your Remote wire for power.
  3. If the Remote wire is powering up with the Head Unit (should be anywhere from 5-12 Volts), check your Power wire for +12 Volts, and check your Ground wire.
  4. If you are getting +12 Volts Power and your Remote wire is putting out 5-12 Volts but your Amplifier still won't turn on, it will need to be serviced.
Jul 24, 2010 | Kicker ZX10001 Car Audio Amplifier
Kicker impulse 254 amp red light on top?
1st check all of your wiring, make sure the remote wire is hooked up, check to see it the RCA's are hooked up. I know this sounds stupid, but i've done it a thousand times, check to see if you hooked up the speakers. If you checked all of those and still nothing, double check your ground. Make sure where you have it grounded, you have all the paint sanded away and its a good grounding point. The red light on the top of the amp, its not a protection light is it??
Apr 03, 2010 | Car Audio & Video
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
Hi on my k600.1 my protection light is on and the power light flickers on and off why is this can you help me please?
TRY TO POWER THE AMPLIFIER UP WITH NO RCA INPUTS AND NO SPEAKERS CONNECTED. IF THIS PROBLEM IS STILL PRESENT, THEN THE AMPLIFIER WILL NEED SERVICE. KEEP IN MIND THAT YOU STILL NEED TO VERIFY THAT YOUR POWER CONNECTIONS ARE SOLID, NO LOOSE GROUNDS, ETC. ALSO, IF YOU HAVE A VOLTMETER, MAKE SURE THAT YOUT REMOTE LEAD HAS APPROX. 12 VOLTS MEASURED FROM GROUND. SOMETIMES A SAGGING REMOTE LEAD THAT HAS LESS THAN 11 VOLTS CAN CAUSE A GOOD AMPLIFIER TO EXHIBIT THESE SYMPTOMS. AFTER ALL, IF THE AMPLIFIER STILL DOES THIS, THEN THE PROTECTION CIRCUITRY IS SEEING ONE OF THE THREE TYPES OF FAULTS WITHIN THE AMPLIFIER AND IS SIMPLY SHUTTING IT DOWN. SOMETIME AFTER WHICH IT TRIES TO POWER UP AGAIN, ONLY TO SEE THE SAME FAULT, THUS REPEATING THE CYCLE CONTINUOUSLY, INDICATED BY THE POWER LIGHT GOING ON AND OFF. LET ME KNOW IF YOU NEED MORE ASSISTANCE....V
Jan 03, 2010 | Kicker KX600.1 Car Audio Amplifier
What does the orange light protection mean
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
.A thumbs up would be greatly appreciated if this answer is helpful to you
Dec 06, 2009 | Kicker ZR1000 Car Audio Amplifier
Kicker KX1200.1 Car Audio Amplifier Logo
203 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
