Question about 2wire (1000-400108-001) Router
Connecting ADSL wireless modem router to COMCAST
Hi prev i am with ATT and i moved to comcast . ATT provided me wireless modem router and now i want to connect to comcast box. Can you please suggest me how to make it work .
    Problem Solver:
  • 12 Answers
Unfortunately you can't because the 2wire is a dsl modem it has to use the phone line to connect to the internet, it would be different if it was just a router but since it is a modem it needs that connection to the phone line in order to work
Posted on Nov 15, 2008
Do i need a modem? if so which are compatible?
When you speak to Comcast you should see if they are providing you with a wireless modem/router that will be everything you need.
If so, you will not need the Belkin router as Comcast will supply you with the hardware you need. If they only give you a modem, your Belken wireless router should work fine with the Comcast modem.
Hope that helps!
Jul 25, 2013 | Belkin N Wireless Modem-Router F5D8633au4A
How should the D-link be setup to work with comcast and vonage? After I set vonage or internet do not work. I tried the comcast modem to d-link and d-link to vonage.
If you want to RECEIVE telephone-calls:
COMCAST ADSL/CABLE modem <---> VONAGE <---> wireless-router
Turn each piece off.
Turn on the COMCAST modem, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the VONAGE router, and wait for its lamps to settle-down to a "steady" pattern.
Turn on the D-link router, and wait for its lamps to settle-down to a "steady" pattern.
Restart the computer that is connected to the D-link router,
and you should have Internet access.
Dec 01, 2009 | D-Link Vonage-enabled Wireless Router...
Moved router to connect directly to the Comcast modem that also provides VOIP. Comcast activated modem and internet works when computer is connected directly to Comcast modem. Router does not connect to...
Your ISP should have given you the following information...
Static IP, Internet IP Address, Subnet Mask, Gateway, Static DNS 1-3.
With that information at hand, follow tis link to the router user manual and go to Page 11 of the manual to go through the step by step process of setting the router up for an internet connection.
http://downloads.linksysbycisco.com/downloads/WRT54GX2v2_ug,1.pdf
Nov 26, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Will comcast support Actiontec - ADSL Modem with 802.11g Wireless Router and 4-Port Ethernet Switch
Comcast will not support that kind of modem. Comcast is a Cable ISP thus the ADSL modem won't work with them because ADSL modem is for DSL providers. Cable Company uses different protocol than DSL. But Comcast will provide you the cable modem if you subscribe to them.
Oct 22, 2009 | Actiontec GT704WG Wireless Router...
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
Netgear wgt624 just stopped connecting to internet
I encountered the same problem, with the same modem and also Comcast, and here's what wound up working for me, after time spent with a nice guy on the Netgear customer support line:
1. Log into router: http://192.168.0.1 (or 192.168.1.1) - user: admin / password: password
2. Under Maintenance, click Router Status. If IP Address is listed as 0.0.0.0, there's your problem-- router isn't getting address from modem.
3. At bottom of Basic Settings, under Router MAC Address, change selection from Use Default Address to Use Computer MAC Address.
4. Click Apply.
5. Click Router Status again-- non-blank IP address should now be listed.
6. Basic Settings will now show MAC address under Use This MAC Address. See if you can get online now. I could, and I hope you can, too!
Dec 04, 2008 | NetGear WGT624 Wireless Router
I HAVE A COMCAST WIRELESS ROUTER THAT I AM TRYING TO USE TO CONNECT MY PC TO THE INTERNET. I TOOK THE COMCAST ROUTER AND PLUGGED IT INTO MY PC AND IT HAS THE GREEN LIGHT ON HOWEVER IT WON'T LET ME CONNECT...
You have a lot of different things going on here.
First, your provider is AT&T so you have ADSL service.
Comcast supplies their service over cable.
AT&T should have provided you with an ADSL modem that is connected to a phone wire. Normally another cable (ethernet, patch, RJ45, Cat5) connects the modem to the network card in your computer.
I don't know what model of router you have but there are 2 possiblities as to type. It can be a regular wireless router or it can actually be a cable modem with a built-in router.
If this is a normal router it will have a port labelled either Internet or Wan (normally, some companies do strange things), you should connect the cable from the ADSL modem to this port.
If it does not have a Internet or Wan port but has a round screw type cable connection, you have no way to connect this to the DSL modem and it will not work for you unless you switch to a cable provider. Even the it may not work because some providers check the MAC address of the unit and will not issue it an IP address unless it matches the one in their files.
Ok, lets say this is a normal wireless router. You have the phone line going to the ADSL modem and then a Cat5 cable going to the Wan port of the router, you are not out of the woods yet because most desktops do not come with wireless hardware. You need to get a Wireless PCI card and install it or if you prefer they also come in USB.
Done? Probably not. If this was a used router it was probably configured at one time and you will not be able to connect to it unless you happen to know the security key. This means you will have to reset the router back to factory default and configure it from scratch. Of course you could luck out and security was never configured for this router but you should still configure it unless you want everybody within range to be able to connect to your router and possibly your computer.
If after this long winded explaination you still want to do this, get back to me with the specific make and model of the router and what operating system you are using and we can go from there.
Oct 17, 2008 | 2wire (1000-400108-001) Router
2wire Wireless router not working w/Comcast cable modem
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Feb 03, 2008 | 2wire (1000-400108-001) Router
2wire (1000-400108-001) Router Logo
502 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
