Question about GE Monogram ZISx420DR 42-inch Side by Side Panel Ready Built-In Refrigerator with Dispenser
Refrigerator door not closing tightly
Our GE Monogram side-by-side refrigerator is about 2 years old and has been working fine until the last week or so. The refigerator door used to close tightly with a magnetic seal strong enough that it required a strong tug to open it and when the door closed a fan would immediately turn on. (I'm assuming it came on to re-regulate the temperature inside.)
Now when we tug on the handle to open the door it opens very easily and when it closes the fan doesn't come on. When closed, the door also appears to stick out a little more than the freezer door even though the rubber seal makes smooth, uninterrupted contact all the way around. The freezer side door works just fine, both sides (refrigerator and freezer) are maintaining their normal temperatures and we don't have any problems with frost or moisture.
Is there some adjustment we can make to get the door to seal strongly again? (Ours is the 36" SXS, not 42".)
  • 2 more comments
  • ssumaylo Feb 10, 2009
    My GE Monogram freezer was repaired recently to replace the control unit in back. Ever since the technician worked on it, the freezer door doesn't close properly. The "wind" generated by the refrigerator door closing makes the freezer door open.
  • Anonymous Feb 20, 2009
    I just got the same problem tonight except the refrig door closes fine but the freezer door doesn't seem to seal up properly - like the magnet isn't pulling it or something. It's affecting the temp in the freezer inside as I can see the ice is starting to melt.
  • robare60 Mar 11, 2009
    I have the same problem. A GE technician was out last week to replace a fan motor on my Monogram ZIS48NYB and now the door won't stay closed.
  • hollandrosem Mar 11, 2009
    My ZIS 36 refirgerator door doesn't pull closed like it used too. It seems as if the magnet isn't working if there is one. I will think the door is closed and then the door alarm will tell me it's not closed. I have taken everything oout of the door and it hasn't made a difference.
  • 943 Answers
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Posted on Oct 15, 2008
My refrigerator won't stay cold. The freezer is working but not the refrig side
I have the GE Monogram ZISB480 side by side. Once again I have your same problem of the freezer freezing (good), but the refrig does not go below 45-50. All the official repair guy did was do a quick 1 hour defrost. I did that also just two weeks ago and it was fine. Now it is not cold enough again. I just looked in the freezer using a mirror I was able to push a 2"x2" trap door open towards the fridge. It must be automated and malfunctioning. Why the heck the repair guy didn't work on that? This week I'll call for another repair job ($85 for him to just come to my door) and ask him to fix the trap door. -Bob
Nov 14, 2010 | GE Monogram Side by Side Refrigerator
I have a monogram ZIS420 the freezer works fine
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 24, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
My two year old admiral refigerator has air entering freezer part
lube the hinge side, sealing face of gaskets with vasoline. Heat gaskets with hair dryer then tape doors shut when hot. wait an hour before removing tape. do this on both doors.
Aug 26, 2009 | GE GSH25JFR Side by Side Refrigerator
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram will not accept freezer/fridge
Turns out the problem was because we didn't shut the freezer door tightly. The temperature re4set itself in about three hours. All OK and no expense :-)
Jun 05, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram leaking water on right side bottom door
If this refrigerator has a Energy Saver mode, turn it on.
Then, check the door gasket for the refrigerator to make sure it's not leaking. Test by placing a crisp dollar bill on the door jamb with the door open, close the door, and you should feel resistance to pulling the dollar out. Check with particular emphasis on the place where you see water leaking or accumulating
Jan 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Nov 28, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
GE monorgram frost in the ice shute
Sounds like the ice door in the dispenser isn't closing properly or all the way which lets warm air in condensates then freezes.
Oct 22, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
1,943 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
