Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
E24 for my canon IXUS 960IS
When I turn it on, the screen is black, when I turin it off, the lens can retract, but E24 appear on the screen, few second then dissappear. can you help.
4 Suggested Answers
SOURCE: e24 code
I've had an E24 problem for several weeks and was unable to take pictures but was able to view old ones. I took apart the camera and used a camel hair brush and removed grit and other stuff from the camera. Put it back together and it works great now. Ron
Posted on Dec 16, 2007
  • 11967 Answers
SOURCE: The Lens error message appears on my canon ixus
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 23, 2009
  • 178 Answers
SOURCE: I get an e24 error when I start my Canon Ixus 60.
If it's a battery compatibility,just replace Canon Digital IXUS 60 battery to have a try.
Posted on Sep 21, 2010
E24
Canon E24 error means that there is a loose connection inside the camera, or even a broken (cracked) flexible pcb.
Open the camera up and check all pcb connections, especially to the LCD and to the lens assembly. With the camera open, power it up and wiggle each connector in turn to see the effect, but make absolutely sure not to touch any of the flash circuitry as it can give you a shock and a burn (absolutely do not do this at all if you have a pacemaker fitted). You'll need to have a set of jewellers' screwdrivers and an anti-static wrist strap (properly earthed) whilst doing this. If I've lost you already, then it's not a DIY repair.
I cannot be more specific as you spent no time at all to provide exact model details, nor even a proper question, sorry.
Feb 26, 2011 | Canon Ixus30 Ixus40 Ixus 50
When turing on my Canon SX100IS camera it opens the lense then closes and gives me an E24 error. I am able to replay phones on my SD Card but not take new pictures since the lense retracts
you get this error message E24 because your lens is slightly out of alignment. Cycling the camera on/off several times will serve to help the lens to work it's way back in alignment.
Even though your battery may be fully charged, as a Lithium Ion battery ages, it begins to lose capacity so you don't have enough power to take any still . Try a different battery.
Clean the battery contacts with a pencil eraser. Sometimes, a dirty battery contact can prevent the battery from providing all the current the camera needs.
Hope this helps.
Jan 24, 2010 | Canon PowerShot SX100 IS Digital Camera
Hi there, I have a Canon Powershot S3IS and just lately when you try to turn it on it comes up with a message that says E24. I have looked through the manual and cannot find anything resembling this...
You have 2 choices here, one is send the camera into Canon for exchange or replace the Camera, this would be based on cost. You can't fix it as no parts are available from the manufacturer to the public.
Apr 05, 2017 | Canon G7 G9 S3is S5is S2is
E24 code
Canon is replacing camera with a
CCD senor problem.......just got a new camera
go on their website and they will tell how to get it fixed
Nov 08, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Error code
I found the answer on another site and was able to fix my camera myself. E24 means your LCD display has come unplugged. What happens if you rotate the screen too much you tighten up the wire and it pulls the connection out of its socket. There ar 4 screws on hedispla, unscrew ad take th back off the screen. Unwind the screen until the wires loosen up. Replug in the loose connector. Resecure the back
Oct 21, 2007 | Canon PowerShot G1 Digital Camera
Can't take pictures
Defective mechanism,  a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Oct 10, 2007 | Canon PowerShot S200 / IXUS 178 Digital...
Camera Won't Start...
I believe it may be an electrical problem. try a different mem card though
Aug 31, 2007 | Canon PowerShot S3 IS Digital Camera
Camera was dropped, lens will not retract, when on/off button is pressed the initial screen and sound appear but then the camera makes a kind of warning sound and E18 appears in the lower left hand co
Perhaps the lens got bumped (if the camera was one when it was dropped) and is out of place. Mine did the same and I sent it in (it was within warranty) and Canon fixed it.
Mar 18, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
118 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
