Question about Frigidaire Affinity ATF7000E Front Load Washer
Wont start. no error. If press start, every light above the start button light up
Please help.
  • Anonymous Nov 02, 2008
    This machine is less than 1 year old and I have the E20 message also. It stops working
    Josée
    • Montreal Canada
Perhaps the control lock light is on. Press options and select at the same time for about 10 seconds to turn off light. That should get you going
Posted on Nov 04, 2008
How do I repair a Cabrio washing machine
Press the cancel button all indicator lights/LED should be off
Select any button except Power, Start,Pause/Cancel
e.g. select buttohttp://www.fixya.com/answer/answerpageslideview.aspx?thid=25219265&ctg=130n "Soil Level"
Press "Soil Level" button and hold for 3 seconds
Release "Soil Level" button wait for 3 seconds
Press "Soil Level" button and hold until "88" lights up on the display and all indicator lights turn on
Watch the display flash any error codes will be displayed. e.g. "81" , "F", etc
Take a note of the numbers and letters displayed, press the "Soil Button" and the next set of codes will be shown. Press the soil button a few times noting down all the codes until "88" is displayed.
If the "Soil Button" doesn't work try another button using the same procedure above exluding any of the buttons mentioned above.
Please post the error codes you have noted.
Oct 13, 2014 | Washing Machines
Wont start
First you have to find the error code.
So! To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Dec 03, 2011 | Frigidaire Affinity ATF7000E Front Load...
Please help me my canon ip1500 wont work. it's
Try to reset the printer:
Press resume button for a few seconds, then release
Press power button for a few seconds, then release
Press two times the resume button
Jun 06, 2011 | Office Equipment & Supplies
As soon as i took the printer out of the box and plugged it in, the lcd screen reads printer error 5100. Please help?
Is it brand new??
Pls follow below steps...
First, unplug the power from the printer and all connections (including usb to the PC as well).
Next, press and hold the Start button while plugging the power back into the printer.
While still holding the Start button, press the Resume button twice (which then allows for Removal of Ink Cartridges(if you are past the limit otherwise leave them in).
Now repeat 1st and then repeat 2nd above.
Press the Resume button 4 times (note that the light will only blink the first two times of the four times that you press the button)
The error should now have cleared so that you can use the printer.
Apr 26, 2011 | Canon Pixma MX410 All-In-One Printer
Have a Frigidaire Gallery Series front loading dryer and it keeps giving me an error(?) code, E68. When I start the dryer, it runs for a couple of minutes and then It starts beeping and flashing this code...
Sorry to read about your problem. this should be your E68 problem
You have a defective button on the control board.
The best thing to do is go into the diagnostic mode.
Turn the dial to Normal. Press and hold the Select and Pause/Cancel keys for 6 seconds, or until the Drying/Cool Down/Press Saver/Clean Lint Filter lights come on.
Then press the Start and Pause/Cancel Buttons 4 seconds. This puts you into the diagnostic mode to check the keys. Now, turn the dial 4 O'clock position, or 75. This will allow you to check all your buttons. As you press each key, it will light all the lights above it. When you press a key and it does nothing or the lights above any certain key stays on without pushing it, this button is stuck. If you can't clear it, you probably have to replace the control board.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Frigidaire Dryers
E,3 flashing on Canon MP140
http://www.devicemanuals.com/model/Canon_PIXMA+MP150_manual.html
How to reset printer canon pixma MP150
  1. When you turn off the printer, then click STOP / RESET and the printer knopkuo POWER.
  2. Without releasing the POWER LED lights up when the power button, press 2 times STOP / RESET
  3. Release the power button, and then a second button - you hit your profile.
  4. The indicator light green. Press STOP / RESET 4 times.
  5. Turn off the printer.
http://tricks-collections.com/reset-canon-pixma-mp150-mp160-mp170-mp180-mp450-mp460-mptool-software/
http://www.klinik-printer.com/2010/02/canon-pixma-mp150-service-manual.html
Service manual above, above that a repair site, above that is a forum for help, above that is your user manual
May 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Wont load
Disc read errors are mainly due to worn out lens or dirty PS2 lens.Clean your PS2 lens to get rid of this problem if your lens is dirty.Watch this video it will help you to know how to clean your PS2 lens.Watch it carefully.
Remember to keep your PS2 in Dust free environment if you don't want your PS2 lens to get dirty.
If your PS2 can not play certain games like Rock band try this tip:
  1. Turn on your PS2 without inserting any disc.
  2. Menu screen will appear like:
  3. Press the ps_b_triangle.gif (triangle) Button to enter Version Information Menu that looks like
  4. Highlight the Play Station Driver as above and again press ps_b_triangle.gif (triangle).
  5. New screen will appear like
  6. Highlight the Disc Speed as above and press ps_b_x.gif button,to enter Disc Speed Menu
  7. And set it from Standard to "Fast".
  8. After you set Disc Speed to Fast, Press and Hold Reset Button to turn off your console.
  9. Then again Press and Hold Reset Button till the Blue Light turns on.
  10. Remove the Reset Button and Press it again.
And after that wait till your game is loaded.
Click here to view full tip.
Nov 16, 2009 | Sony PlayStation 2 (PS2) Console
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Remove error in AR-5316
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
SYSTEM ERROR H4-00
give this a try, Normally this helps.
Mar 10, 2008 | Toshiba e-Studio162D Copier
Frigidaire Affinity ATF7000E Front Load Washer Logo
171 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
