Hp DLP 52 inch. Sometimes after being on for a little while, the blue light starts flashing. What does this mean?
  • llharrio Oct 28, 2008
    i replaced the lamp in my dlp, on suggestion from other post and tv still not work, blue lights flash and tv turns off, no sound no nothing
I have experienced this several times for some reason I can't determine. The solution I have found that works, is I depress and hold the power button (blue button) in until it begins a rapid pulsation for about 5 seconds, then release, your remote should function correctly now, at least mine does, hope this helps.
Gary S. - Temple, GA
Posted on Jan 05, 2009
My id5220 television power light blinks but no picture or sound
1,the lamp ballast is failing
or the mother board is failing
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Feb 16, 2014 | HP Id5220n 52-inch 720p Dlp Hdtv sliv Lamp...
The timer button is flashing really fast, will not turn on. I've tried the reset button with no luck. What started this is, it was on and I accidentally unplugged it.... HELP!!!!!!!
hello my name is rico and i work on tvs sometimes. this problem is common on mits dlp, this mean: 1 check your lamp, 2 there is sensor(thermal sensor) that will control tv for not turning on. by light engine. if can do that u will save alot of money, feel free to call me anytime at 602-810-7149. i will check with mitsubishi tomorrow, so call me whenever. thank you.
Dec 29, 2010 | Mitsubishi WD-52525 52" Rear Projection...
How heavy is a hitachi 52 inch dlp tv
The weight of the hitachi 52 inch TV is around 94.1 lbs 0r 42.6 Kg
Thanx
Jul 31, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
52 Inch Zenith TV has red blue and green squiggly lines what is wrong, no picture
I belive that the red light means that it is off and the blue means that its on
Jun 10, 2009 | Zenith D52WLCD 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Have little dots of light on screen and colors are starting to run on my HITACHI projection 52 inch telivishion
If your set is a DLP model set with a lamp, then I would assume your Light Engine has failed. These are very expensive to replace, however, if it's not a DLP model then send me your model number for further diagnosis. Also the date of purchase.
Mar 21, 2009 | Hitachi 50VS69 50" Projection HDTV
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Light
My RCA 52 inch was doing the same thing.  TV guy had me use a regular hair blower blowing very hot on the power supply board ( bottom left in back). After a few minutes the tv would come on.  He replaced 2 capacitors, charged me $100.00, plus the $95.00 service call, and is working fine now.  This was a month ago.  So far so good.  He only took the board to the shop, not the entire tv.  Hope this helps.
Oct 04, 2007 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
Electro Med Services...
