Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Picture unclear blue/red colors around figures.
I try to use the magic focus button to solve the problem as suggested in the manual, it seemed as if it was working but then a green # 5 appeared on the bottom of the screen and the problem was not solved, any suggestions?
  • bihtravel Dec 30, 2008
    around every figure and some letters these blue yellow and green colors keep appearing.
    Genius:
  • 2,920 Answers
You need to have the tv re convergeged to get it right
Posted on Oct 30, 2008
Can't get full screen. tried all aspect selections. also color is off. can't get it to adjust. magic focus dosen't help. any suggestions?
Magic focus button don't work.Colors lines R,G,B mis alignment,have colors shadows picture or 3D pictures.The tv have a problems known as a convergence problems,it dead.The tv convergence board it dead,must require replacing 2 STK convergence ICS and some or all it resistors to solved the tv convergence picture problems.The shop,will cost u $300-350 for parts and labors.
Oct 07, 2010 | Hitachi 57F510 57" Rear Projection...
I think that it is the green because i did what you said and it is still there. there is a feature on my tv called magic focus it brings up the colors and the blue and the red are very focused but the...
This tv is a DLP projection tv right?Magic focus button push don't solved the focus picture problems,have colors shadows or 3D pictures problems?The tv have a problems known as a convergence problems,it dead.The tv convergence board.Must have it 2 STK convergence ICS and some or all it resistors to be replaced to solved the tv picture convergence problems.The shop,will cost u $300-$350 for parts and labors.
Oct 02, 2010 | Televison & Video
Hitachi 43fwx20b Convergence Problems
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 61SDX01B Dark Picture and bad color
There isn't anything you can do yourself for this problem, but it should be worth having a qualified technician look at it.
Sep 09, 2009 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61SBX59B 61 inch has brightness and color problems
I would say the crt's are at the end of their life.
Sep 09, 2009 | Televison & Video
Will not show red color in picture, magic focus shows red though
You have a projection light element out. I had the green element go on mine. I had a service agreement so a repair tech changed it.
Feb 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Yellow and blue color ruins total picture on 50" tv,can't get rid
lupe0112,
I'm no expert, but I think that you have a problem with the convergence of the 3 color guns. I've been working on a similar problem. As a first step, have you tried "Magic Focus?" The Magic Focus button for the Hitachi 53UDX10B is at the left of the small front panel controls that also include your RCA composite and SVideo connectors. Let the set warm up for about 20 minutes (as recommended by the user guide), and then press the Magic Focus button. When you press the Magic focus button, the set will auto align the 3 color guns. If this doesn't fix your problem, unplug the TV for at least 4 hours and try again.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Blue/Yellow out of focus on Hitachi 43UWX10B
You will need the convergence circuit repaired......IC's replaced,
B+ resistors checked and then magic focus activated......T.
Sep 17, 2007 | Philips 60P8342 60" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
