Question about Frigidaire FRS23R4A Side by Side Refrigerator
Fridge keeps freezing thing
My fridge just started to freeze items on top shelf. Was set to factory setting what m,ight be the problem or where should I start
  • Anonymous Nov 09, 2008
    I HAVE THE SAME PROBLEM BUT I HAVE TRIED ADJUSTING THE TEMPERATURE, AND NO MATTER WHERE YOU SET IT. IT JUST SEEMS TO FREEZE.
  • 943 Answers
HI thanks for your question. the factory setting is ok. try to adjust the other setting to a higher# try this give it some time to adjust and set the other to a lower# thanks
Posted on Oct 15, 2008
My refrigerator keeps freezing things...,.changed the gaskets around door and still have the freezing probkem
Most fridges have a cooling vent above or on the side of the top shelf. This is where most of the cold air comes from, so keeping food away from here may preventfreezing. ... Some side-by-side refrigerators (particularly older models) feature a vent that funnels cold air from the freezer into the fridge.4 Aug 2015
How to Prevent Your Refrigerator From Accidentally Freezing Food ...
refrigerators.reviewed.com/features/how-to-prevent-accidental-food-freezing-in-fridge...or try this link... refrigerator keeps freezing things Google Search
Oct 23, 2017 | Refrigerators
Items freeze on top shelf of refrigerator. All temps are per factory specs.
If it is only freezing on the upper shelf then you will need to replace the "air diffuser". It is not closing when the refrigerator temp is reached. Here is the part to order.
Nov 05, 2012 | Whirlpool GSC25C4Ey Side by Side...
Refrigerator side too cold
refrigerators only have one cooling system and that is for the freezer. The fridge part is cooled by sending a portion of the air from the freezer to the fridge. your fridge thermostat controls a fan that turns on and off as needed. first step is to make sure this is working, and not stuck on. turn your fridge to a somewhat warm no and open the door for a few minutes to allow the cold air out then check and see see if it gets very cold again within say an hour. if it does your fan is always on and you need to repair it. if that is working then you have to play with both freezer and fridge settings. best thing is to get a cheap thermometer and check your freezer temp. it should be around 0 to -5f if it is colder than that frigid air blowing into your fridge too cool the whole area will freeze anything close to the vent. once you have your freezer set then start adjusting your fridge. personally I have mine set at 34f knowing that some things on the top shelf will freeze. but I like my cola's COLD. so I put things like butter that are harder to freeze at that level. but if you don't want anything to freeze then a temp of 37 -39f is correct for your fridge. so it comes down to freezer temp, the amount of time the fan is on, and proximity to the vent. good luck
Nov 28, 2011 | Cars & Trucks
We just purchased this model, and the items in our refridgerator keep freezing, including the milk in the door. We have turned down the setting to 2 and it keeps occuring, is this common? Mostly things...
I've actually ran inti this problem alot. its just a design flaw. the objects that are freezing are close to the direct flow of cold air coming from the freezer into the fresh food compartment. adjusting the temperature will result in the same condition. The only thing you can do is rearrange products closest to the air duct. You may even gave to rearrange the shelves. Just ran into this same problem yesterday when i was dispatched to a customers home. Its just a stupid flaw in the design of the fridge.
Feb 08, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My fridge side is too cold -everything freezes. I have the fridge setting to off and the freezer turned down to 1 and items on the top shelf in the fridge still freeze. The fan works well.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 22, 2011 | Refrigerators
Have a GE side-by-side profile 25.4. The fridge side is too cold and freezing items in back of top shelf and items in the veggie draw. Settings are 4 for freezer and 2 for fridge and things still are...
there is a air damper that lets the air in frome the freezer side,, it should be in the back top left corner on the fridge side turn the controls to off and listen you should hear a faint sound like a flap closing,, if not it is either stuck wide open, or the little motor has went out,,,( for a temp fix you can tape some of the opening off until you get the parts replaced
Jan 19, 2011 | GE Profile 25.5 Cu. Ft. Side-by-Side...
MY 9 YR OLD FRIDGE IS FREEZING MILK, JUICE AND ALL LIQUIDS IN THE MAIN COMPARTMENT BUT NOT NECESSARILY ON THE DOORS
you gotta send model number,there are different things that can cause this,if the freezer is on top,the cold air from the freezer gets blown into the fridge in the center of the top shelf so if any food is near this it will freeze if the air isn't monitored, check the settings first,it could be set to high, there's a cold control or thermostat that monitors how much air comes into the fridge and when it reaches a certain temp it shuts off but it sounds like your having a problem with it,also on some fridges they have a damper that can mess up,there's a door on it that doesn't close and the cold air just keeps coming into the fridge and things start freezing up
Dec 24, 2009 | Refrigerators
Ed22pwxxn00 setting on 3 top shelf items freeze. Is our 18 yr old fridge going out?
Adjust the freezer damper to a higher number to reduce cold air flow to the fridge section. This will eliminate freezing in the fresh food section.
Aug 29, 2009 | Whirlpool Refrigerators
Fridge is freezing food on upper shelves
Either damper assembly between fridge and freezer is not working correctly or the thermostat is bad
Sep 05, 2017 | Frigidaire FRS26H5AS Side by Side...
Fridge area freezing food; water dispensor line freezing
sometimes when the cooler weather comes in you may need to chnge temp setings to a warmer setting to prevent some items from freezing ie: leafy vegetables, water bottles, eggs, etc etc.
now if you are having total freeze up of everything in the ref section then you could have bad temp control or damper assy.
Oct 22, 2007 | Frigidaire GLRS234ZA Side by Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
303 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
