Question about Canon PIXMA MP830 All-In-One InkJet Printer
CD/DVD Print tray does not work - apparently bad logic board
The CD/DVD Tray on my MP830 does not work. It slides in, fails to recognise the disc and slides back out, therefore refusing to print on the disc. The first time I took it in (within warranty) they said they just needed to clean or adjust the sensor. The second time it happened (without warranty) they said that they couldn't find the problem, but that it was probably the logic board, which would cost several hundred $ to replace. Is there any way around this? Can these board be bought cheaply somewhere?
  • lawamos18 Oct 21, 2008
    I have the exact same problem with the Canon IP5300
  • 76 Answers
No, Canon only sell through supported dealers. If it does work and sometimes stops working, it could be cd tray is dirty or the disc are too shinny calls the sensor to reflect back to the tray. some cheaper disc do not work as they are not matte white.
Posted on Oct 20, 2008
CD does'nt slide anymore inside the printer to be printed at the second step, after going down at first
Either the sensor and/or the laser lens inside the tray are dirty, a common fault printers)or you are not aligning the disk properly when placing in the tray. You can try using a CD\DVD cleaning disk and a can of compressed air to blow out dust. If this fails uninstall the printer's drivers and software and reinstall everything from the beginning. If that fails return for repairs. NEVER use stick on disc labels, only use write on discs
Mar 18, 2014 | MicroBoards Computers & Internet
Dvd/cd rom not working
The drive may have failed. It can't read the disk.
Jan 16, 2014 | Computers & Internet
Can't print on CD's with Canon MP830
In the main menu on the LCD do you have a dvd /cd print option?
If not you need to change the rgion code to other than US.
Oct 15, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I can't print from tray 2 or 3 from either Mac or PC
You need to remove the trys affected, most likely there is a sensor issue.
Remove the trays and check behind them as paper sometimes falls behind blocking the sensors. If so, remove the paper.
Also, check the paper slides in the tray themselves, remove the paper and slide them in and out all the way, put the trays back in the machine and put the paper back in the tray moving the slides right up against the paper and close the door. It should work normally from now on, if not try a reboot one more time.
Mar 26, 2009 | Xerox Phaser 7700DX Laser Printer
CD/DVD Tray open; Close Tray to print
This solution is taken from the HP website.
Follow these steps to print on a CD or DVD.
  1. Make sure that the CD/DVD tray is completely closed (completely inserted into the product).
    NOTE: Make sure that the side of the tray that holds the CD/DVD is inserted into the printer first.
  2. In HP Photosmart Essential, click the Print tab.
  3. Click Printer Settings and then click Advanced to open the printer properties.
  4. In the properties, click the Features tab.
  5. In Paper Type , select Printable CD 120mm .
  6. In Source , select the CD/DVD tray .
  7. Save the settings and then again attempt to print on the CD or DVD.
Feb 05, 2009 | HP Photosmart D5360 InkJet Printer
Wont print
I think it might be the rollers of the printer are going bad. since its need to be in timing correctly, what i do is this.
when the printer start taking the cd tray in a bit push it in aq bit while its going in. DONT FORCE it in just push it in as it goes in, the roller are not catching the CD tray properly, its not the tray itself as youve found out, the rollers are going bad or are to dirty.
try cleaning the area of the CD tray with alcohol, then see if that helps.
good luck
Dec 04, 2008 | Epson Stylus Multifunction Inkjet Printer/...
I read on another site that you must wait until prompted on the screen to put the tray into position. Opening the inner door and loading the tray before asked to and then pressing OK was the key to fixing the problem on the MP830.
It's the simple things that always get you into trouble, I guess.
Oct 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Trying to print onto cd-r
I got this model for Xmas & spent over 2 hours with the same problem. How can you close inner tray when you're only supposed to push the tray half way in for printing onto disc? It doesn't make sense, it's a contradiction and the manual doesn't give any explanation, An absolute piece of Junk! It's going to be 'dumped' back to the retailer tomorrow! I've never had such crap!
Jan 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
330 people viewed this question
old marine
old marine
