Question about Everex GA3400 Refurbished AMD Desktop Computer - AMD Athlon 64 3400+ 2.2GHz , 512MB DDR, 120GB HDD
Help how can i set my pc back to factory settings. I need to do this so my ascentive ( performance center will work again because it tells me i need to reinstall it but this pc didn't come with a recovery cd. Helpless
  • Tammy Anderson Oct 15, 2008
    i need help fixing my APCMAIN - ascentive / performance center it tells me to reinstall it. How do i fix it ?
    what will ccleaner do? and how does it work?
    Sergeant:
    Champion:
  • 334 Answers
DL FROM MAKERS SITE ALL SOFWTARE U NEED OR WHO EVER MAKE STHAT SOFTWARE DO WINDOWS UPDATE OK RUN CCLEANER.COM TOOL
Posted on Oct 15, 2008
  • nick helpap
    nick helpap Oct 15, 2008
    its cleaner to get junk files temps out so sofware will work right then go web site dl latest verison of apcmain
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
Factory settings samsung pc np-r580
Before you start the recovery process be sure to have backed-up your data. Returning to Factory state will completely erase you hard disk. You do not have to do a restore to factory settings; Samsung provide various levels of recovery
Certain links from this webpage
Global Download Center
should tell you how to perform this task. There is more than one way of doing it.
Consult chapter 4 of the manual http://downloadcenter.samsung.com/content/UM/201409/20140901105918371/Win7_Vista_Manual_eng.pdf
This discussion from the Microsoft community sumarises it:
how do totally reset my samsung np r580
12.February.2015
Feb 12, 2015 | Samsung Computers & Internet
I have a HP L7580 all in one printer. When I try to scan something, it tells me that the lcd list needs to be upgraded. How do I do that?
First try to power cycle the printer by turning it off and turning it back on. If this does not help, unplug the printer for 15-20 seconds and plug it back in. if this does not help, a HP employee recommended this for a networked printer (meaning connection is through network not directly to PC):
If you installed via network, then you need to send the 'scan to' settings to the printer to update the LCD list Depends on the hp software, follow following steps to update the 'Scan To' settings to the printer: HP Solution Center or HP Director Click Settings , and then click Scan Settings . Depending on your software version, click the option available to you: Scan to... Setup Button settings Click Scan to... Setup . Continue with the on-screen instructions to create a list of destinations for scans. Try scanning again from the printer control panel.
Other than that, the only solution that seems to work for most is to perform a factory reset. Here are the steps:
Settings/Tools/Restore Factory Default or
Setup/Tools/Restore Factory Default
This is done through the menus on the printer itself.
May 09, 2011 | HP OfficeJet 7410 All-In-One InkJet...
My 6730c will not send SMS anymore. They remain stuck in the Outbox: Sending Failed.
First, move the MMC. If still can't send, restore the factory setting. You can do it with master code *#7780# and the standard phone's code is 12345.the last solutions you can perform master reset with code *#7370#. But don't forget to backup your data in phone memory to MMC like contacs and message. After you perform a factory setting or master reset please backup all of your data in MMC to PC. And then format your MMC. 100% works, good luck
Dec 24, 2010 | Nokia 6730 classic Cell Phone
En d?marrant mon ordinateur, j'ai toujours le m?me message d'erreur : c:\program Files\ascentive\performance center\APCMain.exe abnormal program termination comment faire pour m'en d?barasser
Salut Francoise,
'Ascentive' est un programme pour spyware, oui? Je recommande que vous désinstalliez 'Ascentive', et, téléchargez alors et installer un meilleur programme 'Spybot - Search and Destroy' appelé. C'est plus fiable et très simple pour utiliser. Je n'ai jamais eu n'importe quels problèmes avec spyware, puisque j'ai installé Spybot.
J'espère que ceci est serviable à vous. Bonne Chance!
Chris (ziraffa)
Jan 11, 2009 | Computers & Internet
I need to re install my ascentive performance center
StopBadware.org released a badware alert about PC SpeedScan Pro today:
We find that PC SpeedScan Pro is badware because it does not disclose the fact that it installs additional "Performance Center" software and fails to remove this software when PC SpeedScan Pro is uninstalled, and because it repeatedly displays notifications that exaggerate the performance impact of various ‘errors’ found on users’ computers, in order to induce users to purchase the full version of the software.
The software was distributed via a website called finallyfast.com.
We attempted to contact the software publisher, Ascentive, via e-mail, but we did not receive a response.
We currently recommend that users do not install PC SpeedScan Pro, unless users are comfortable with the behaviors we have identified or until the application is updated to be consistent with the recommendations made in this alert.
I had been hearing a lot of good things about the Ascentive Software release of PC SpeedScan Pro. It claims to get those gigabytes of data you have accumulated straightened out and get your computer running like new again. PC SpeedScan claims to fix registry errors that can make your computer slow while it sorts through the errors as you are accessing your programs and files. Apparently it does not work too well. See our recommended computer optimization programs here.
After hearing some of the complaints about the Ascentive software, you may want to stick with computer optimization programs that have stood the test of time. Here are some good reviews on SpeedUpMyPC 2009, TuneUp Utilities 2008, and Optimize 2.0 - definitely worth a look!
I would personally recommend ncleaner. It has been my hands-down champion for months now.
Trust me Albert, stay away from the ascentive con-artist program. ncleaner will clean up your machine, and I also recommend you scan with Spybot, as Ascentive might have dumped some cookies on yr machine.
Good Luck and Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Computers & Internet
I need to re install my ascentive performance center for the speed scan pro application
Chris (ziraffa)
Ascentive Performance Center
I need to re-install the Ascentive Performance Center
Nov 21, 2008 | Computers & Internet
ApcMain ascentive preformance center
everytime i log on i get amessage saying to install apc main
i keep trying to install then it says i already have
Oct 15, 2008 | Computers & Internet
No messagesto be able to sent
check the "message center number" in the "message settings"("message setup") ...
you can get the correct "message center number " by calling to your network provider "customer care" ...
ask them the " message center number" note that down and enter that "message center number " there ...
if you still persist the same problem then call to customer care of your network provider and complain the same about it ..
they will have a cross check and get you back .. there may be some error ..
if the customer care people tell you that there is some error in your handset then just give "restore factory settings"("reset") it will ask for the "security code"("password") enter that and after performing the "restore factory settings" then enter the "message center number" so that if there is any firmware problem that will be solved by giving the"restore factory settings"("reset")...
after performing the "restore factory settings"("reset") once you restart your phone ...
your problem will be fixed ..
rate my solution
Sep 05, 2008 | Motorola Cell Phones
Everex GA3400 Refurbished AMD Desktop Computer - AMD Athlon 64 3400+ 2.2GHz , 512MB DDR, 120GB HDD Logo
67 people viewed this question
Top Everex Computers & Internet Experts
Jerry Umali
k24674
Are you an Everex Computer and Internet Expert? Answer questions, earn points and help others
