Gateway computer power cord will not stay in the back of the computer. Is the computer's port bad or do I just need a new power pack.
From the information that you have posted I would suggest that you try a new IEC Cable in the back of you computer. As long as there is no physical connection damage then the computer's port should be fine.
Posted on Oct 15, 2008
Is there an internal fuse for the incoming power for a gateway laptop computer
No... there aren't usually fuses for laptops. You may have a bad power cord... it's a transformer that converts 100-250VAC to 12VDC usually. Get a new one, but before you do, borrow a friend's with the same brand of computer to see if that's your problem or you can have them charge up your battery pack and see it your laptop powers up normally. If it doesn't check my pther post on a gateway laptop that fails to boot up normally. Could be something else!
Mar 21, 2015 | Gateway Computers & Internet
When I turn on my laptop the power lights up and shuts off after a few seconds
either a bad battery, or charge port. even if the battery was fully charged it will still keep the light on, try this. plug it in, and power it on, then remove the battery completly, the computer should stay on, as its running off the plug power cord. if this port is a bad one the pc will shut off immeadatly. and if it stays running then it will be the battery.
Jan 06, 2011 | Gateway M-6843 Notebook
My gateway netbook wont charge, they sent me a new battery but again it will not charge, what could be wrong?
The problem might be either from the charger or from the laptop.
To confirm and repair if it is the charger, all you have to do is to plug the charger on another laptop to see if it will charge, if it does not charge, then you know the fault is from the charger, and the solution is for you to replace it with a new one, before you replace it, try to connect another power cord to the charger, because sometimes the power cord might have been burnt, that have happened to me twice and replacing the power cord solved the problem. But if replacing the power cord does not help, then you need to change the power cord.
To confirm and repair if it is the laptop, plug in a new charger to the laptop, if it does not charge, then you need to understand that the charging port of the laptop is faulty and needs to be replaced, have a repairman replace the charging port for you.
Take care and good luck
Oct 31, 2010 | Gateway LT2021u Netbook
835gm powers up, but monitor power button goes amber, screen stays black and fan stays on high rpm. Had problem in past, usually solved with restart, but have had this computer in storage for awhile, now...
1. It could be bad connection of Memory, CPU, Graphic-cards etc. Try to reseat them aswell.
2. Have you tried replacing the power-unit?
3. Some BIOS es are a bit 'stupid', do you have a fairly new and working monitor plugged in directly (bypassing KVMs)?
Worst case is 'BGA-slip', the bridge-chips and/or onboard GPU has some broken solderings, typically happens to Laptops.
Jul 18, 2010 | Gateway 835GM (835GH) PC Desktop
My power cord does not stay charging while plugged in. Normally I hear the beeping as it conects and disconnects, up to 20 times a minute. Do I have a bad power cord? Is the best result just to purcharse a...
If it keeps connecting and disconnecting, it could be either the power adapter or the motherboard, but chances are it's the power adapter (and that's the cheaper solution too). You can usually get a new power adapter for $15 or $20, and that should take care of your problem.
Jun 01, 2010 | Gateway NV5215u Notebook
Have a Gateway Laptop Computer Model #MT6708. Previously computer had blank screen and no power. Currently purchased new battery and power cord. Computer now operating screen and power is on. However, when...
First thing check that the battery charge light is on when the battery and the charger are connected.
If it is it indicates that the power supply is charging the battery,
If it isnt it may indicate a fault with the battery or that the charger is not compatable with the laptop or that there is a fault with the charger.
If the battery is charging then try running the laptop on battery only without the charger and on charger only without the battery.
This will eliminate which one is faulty.
You mentioned that if you wiggle the cord then the light comes on again.
Check to see if the charger end plug is lose or the actual port on the laptop is lose.
If the charger plug is lose then return to seller and make sure they gave you the correct charger. if the actual port on laptop is lose then perhaps u got a bad connection and you need electrician or local laptop technician to open it up and solder properly on motherboard.
Let me know how it goes.
Oct 26, 2009 | Gateway Computers & Internet
Gateway 310 X will not power on
Hi. this is a failed power supply. the power supply pack will have to be replaced. it located on the rear side of the tower in the upper corner. its where the power cord plugs into. replace the power pack and this will fix the issue at hand.
May 17, 2009 | Gateway 310 X (310XSP) PC Desktop
Gateway mx6453 thought I heard a snap and the comptuer went dead.
It sounds like you have a fault with the power port on the mainboard or power board (quite a few gateways have a separate power board) , the battery won't charge if this damaged or loose which would explain the dead battery. The smell is probably caused by sparking on the loose power port. I wouldn't try to power it on anymore as you may damage it further. it is possible that the area around the power port is burntout therefore rendering the powerboard or mainboard useless but they are replaceable at a cost. If the laptop is still under warranty then you will need to take it back to where you brought it.
You will need to take it to an engineer to have it assessed unless you are able to make the repair yourself. Good luck hope this helps.
Mar 04, 2009 | Gateway MX6453 Notebook
Power Cord Slot Repair for a Gateway ML6230
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Nov 18, 2008 | Gateway ML6230 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
