Question about Dishwashers
Diswaher fills with water and then I hear a buzzing sound on the capacitor next to the motor. The motor does not turn on to spay in the dishwasher.
  • 171 Answers
Hi tonyh514,
I'm Harvey the Master Plumber.
Your problem is: Diswaher fills with water and then you hear a buzzing sound on the capacitor next to the motor. The motor does not turn on to spay in the dishwasher.
Sorry, it sounds like the motor's starting capacitor has failed. The unit must be removed from the cabinet to allow for easy access. With some models you can change it out, others you change both the capacitor and motor. I don't recomend this repair to the average homeowner. You might consider the Repair Directory for a repairman.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
Fridgeaire washer dryer stack unit. The washer side doesn't complete cycle.
check door lock switch if not water valve for cold side is not on or valve is defective buzzing sound from water valve means not opening
Jun 27, 2016 | Frigidaire Washing Machines
Hobart dishwasher wont fill and motor hums
Hi SubaruB4
it may be the electric valve where the water comes in if it doesn't open when switched on water wont enter
Dec 26, 2017 | Hobart Dishwashers
Washer buzzes and won't agitate or spin. Only will fill with water.
Almost certainly with that sound, the motor start capacitor has failed. It will be located either behind the control panel, or underneath next to the motor.
Dec 17, 2013 | Maytag Parts Washing Machines
My kitchenaid diswasher will fill and drain with water but when the wash cycle starts there is a buzzing sound and nothing happens. Model 310253306 about 13 years old. The was cycle not working was not a...
The buzzing sound would be the motor trying to start and it not being able to turn...
either something is stuck in the pump and holding it from not starting or the motor its self has gone bad and will not start.
Apr 23, 2011 | KitchenAid Dishwashers
We have a bosch classixx free standing dishwasher and the base is filled with water, we ve removed the filter but there doesn t seem to be anything there causing the blockage.any ideas?
Hello Becky,
The most likely causes are a failed drain pump motor (or capacitor) or a jammed/broken pump impeller. There is a very simply simple test on classixx models which which help you to determine the cause, or where to look next.
1. Turn the wash cycle selector to any wash cycle so the "ON" light is illuminated, but do not press the START/STOP button.
2. Open the door and pull the lower basket out.
3. Locate the 'float', lift it up fully and keep it held up.
(The float is a dome/mushroom shaped protrusion in the base of the washer just to the left of the drain and partially hidden by the spray arm)
When you lift the float, the drain pump should run instantly and the water should drain from the washer. If you can hear a low hum from the pump motor in the base of the washer, but the water doesn't drain, then it's likely that the pump impeller is jammed or it may have broken away from the spindle. If this is the case, try repeatedly lifting and dropping the float fairly rapidly. Repeated stop/start signals to the pump motor can sometimes free a stuck impeller.
If you cannot hear any noise from the base of the washer when you lift the float, then the drain pump motor or the motor capacitor may have failed. A failed capacitor is often accompanied by a buzzing noise. Further testing will be required to determine the exact cause of the fault.
Please try the simple test above and then post back with the results for further assistance.
Hope this helps.
Mar 05, 2011 | Bosch 24 in. SGS43C12 Classixx...
Has power, nothen works
Hello & Welcome to FixYa
If it has power but nothing is working then first check the control, if the lights are there on the control, then try to hear if the motor is running and if it does fill with water. If it fills with water and you hear a humm/buzz sound from the bottom panel then it is the motor that is bad and needs replacement. If it is completely dead then it is the main board also known as the electronic control that is bad and needs replacement. Please get back to me if you have any other questions.
Dec 12, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
DIshwasher stopped during wash and won't run or drain.
Sounds like a drain motor startup capacitor, or stuck pump. Try disconnecting power and turn the water pump manually. Some disassembly required. Then after a few good hand spins replug and try again.
Mar 05, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
Thermador dishwasher DWU244, error code "F" does not run?
f code is a fill fault problem to much or to little water to determine the problem is to hit cancel drain buttons on the front of the machine and wait for cl on the display turn off machine and wait 30 seconds turn back on and the first thing you will hear is the drain motor turn on for 15 sec then you should hear the water filling into the machine if you dont hear water filing then check to see if the valve under the sink is open to allow water to fill machine
Feb 15, 2009 | Thermador DWU244 Dishwasher
Dishwasher not working
Nothing by the sound of it. The humming may mean the main pump is stuck. If you are able, remove the pump & turn the impellor by hand (or screwdriver) just to make sure its free moving. Put it back into machine & see what you get. Could also mean that the capacitor on the main pump (if it is a capacitor start motor) has failed.
Jul 19, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
356 people viewed this question
Top Dishwashers Experts
