Question about Black & Decker Blower Vacuum Mulcher 1 Ea
Problem connecting Black & Decker leaf blower switch
Last Fall, my Black & Decker leaf blower stopped working abruptly. By bypassing the two switches (main & safety), I confirmed that the motor was working perfectly. So, it had to be one or both of the switches. Being the procrastinator that I am, I waited until now to order new parts.
I just received the order today and noticed that the new main on-off switch pictured above has a wire connected to one of the switch end terminals. The old one does not. The power wires were connected to the available terminals on the on-off switch (bottom and 2nd. from top terminals), which completed the circuit.
On the new switch, this wire is connected to a terminal which is connected to another component (resistor?). So, what do I do with this extra wire?
Thank you.
Jacques.
  • blueshark123 Oct 16, 2008
    Forgot important detail: Black & Decker blower is model BV1500 Type 1.
3 Suggested Answers
bbreton
  • 437 Answers
SOURCE: black and decker leaf blower is on all the time
go to www.dewaltservicenet.com. Put your model number in the site and it will come up with a parts list and diagram for your blower.
HTH
Good Day.
Posted on Nov 18, 2009
SOURCE: My motor brushes at end
Try Platt Electrical supply - 800-257-5288 (Platt.com) BLACK & DECKER #89754-01 REPLACEMENT BRUSH. It seems the entire motor head was manufactured by DeWalt and is now obsolete. I don't know if these brushes will fit, but someone there may help.
Good Luck!
Posted on Aug 31, 2011
My leaf blower was working fine and then all of a sudden it stopped working
Try a different outlet, maybe the ground fault interrupter tripped on the circuit.
Sep 12, 2016 | Black and Decker USA Black & Decker LH4500...
Black decker troubleshooting
could be broken wire or switch went bad.
Jul 27, 2014 | Black & Decker Leaf Hog Blower Vac With...
Black decker manuals
First I would check to see if the wood chip is not obstructing the fan blade. If the fan blade turns freely and the motor still does not start, you will need to open the unit and check to see if your getting 110V A/C going to and after the switch using a DVOM meter. (Digital Volt Ohm Meter). Wear insulated gloves since you will be working with 110V. Use extreme care when probing the circuit. Before plugging the blower in after it has been dismantled, disconnect the fan motor wire to prevent accidental start up incase a connection is made. If there is power present before and after switch, check to see if the fan motor is getting power from the switch. If there is power present at the fan motor, then you have a open circuit in the field winding in the motor. If that's the case, Sears has a nice on line parts directory that covers many appliances including your blower. You will need the make and model number off the case of the blower to input it into the system. Good Luck and hope this was informational.
Jan 04, 2014 | Black & Decker Leaf Hog Blower Vac With...
Will start but wont run.runs only a second
It is possible that the ON/OFF switch is bad or the wires that connect to the switch are loose and are not making permanent contact. Check the switch.
Dec 04, 2010 | Black & Decker Leaf Hog 12-AMP Electric...
How to do I convert it from blower to vacuum..it just stopped sucking and the blowing is not strong
My LEAF HOG works fine on blowing - but when I switch to vacuum it wor't
start. What's the difference from going to Vacuum from Blower???
Dec 03, 2010 | Black & Decker & Leaf Hog Blower / Vacuum
Black and decker leaf blower is on all the time the on off switch wont turn it off
HTH
Good Day.
Nov 18, 2009 | Black & Decker Garden
The engine stopped running even afetr changing electrical cords and outlets. Can it be repaired?
Yes, but you may find it as cost effective to purchase another. It could have an onboard circuit breaker, or on-off switch bad, and even the motor itself.
Nov 10, 2009 | Black & Decker Leaf Hog Blower Bv4000
Black and decker leaf hog on off switch schematic Switch doesn't engage
Take out all the screws. Gently remove half of the case. Put a shim in behind the plastic pivot that rocks the switch. I rolled up a 1/2" by 3" piede of duct tape and jammed into the back of the oval socket for the rocker. This pushes the rocker against the switch hard enough so that it rocks the switch properly. Snap the case into place and test the switch before you put the screws back in to make sure it is now working properly.
Aug 27, 2009 | Black & Decker & Leaf Hog Blower / Vacuum
Black and Decker leaf hog, worked fine last use.
I posted this solution on another similar thread, but it may pertain here.
I have this unit. Mine stopped working today after being warm on the handle the last few uses. I opened the unit up (torx 15) and smelled, then found that a fused wire coming off the motor had burned/melted/separated at a plastic plug right inside the handle. I'm not sure if it had anything to do with it, but in this same compartment of the handle there was an anti-theft strip floating around. I called BandD and they said the BV4000 type ONE has been recalled. http://www.cpsc.gov/cpscpub/prerel/prhtml07/07005.html
Jun 10, 2009 | Black & Decker Leaf Hog 12-AMP Electric...
My black and decker leafhog blower/vac smells like something is burning
Black and Decker has issued a recall notice for Type 1 BV4000 because "a loose connection between the unit and an extension cord can create heat, posing a possible fire hazard" Says to STOP USING and call 1-866-853-2138 to arrange for free repair. (Found info by Googling "Black and Decker Leafhog", navigate to Black and Decker website and click "Important Safety Recalls" button at bottom of page.)
Nov 08, 2008 | Black & Decker Leaf Hog 12-AMP Electric...
Black & Decker Blower Vacuum Mulcher 1 Ea Logo
204 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
