Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi wd-62525 projection tv has pink horizontal lines. Need to know what it would take to fix it and cost.
Got tv from daughter about 3 years ago. She had just had a bulb replaced. Do not use often, maybe once per week. It now has pink horizontal lines rotateing from bottom to top. Called repairman. He indicated it would be $65 for house call and probably a minimum cost of $300 to $600 to repair but gave no indication what the problem might be.
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: WD-62525 horizontal lines in picture when using component inputs
code 12 means the set isnt experiencing any shutdown symptons. I would check for more capacitors in the same circuit where you found the other often they show no visible sign of deterioration. If you need a service manual to figure out which capacitors are in that same circuit you can get the manbual for your set for 10.99 at the following link. They will even email it to you if you go back to the site and let them know you want it emailed. heres the link hope it helps.
http://servicemanuals.vstore.ca/
Posted on Jan 20, 2008
SOURCE: Mitsubishi WD-62525 DLP has no picture
the lamp went out in our wd-62525. I replaced it and cleaned the filter, now it makes a strange noise every few minutes and the picture gets distorted, then it's fine.We have had this set for only 16 months and have had to replace the mother board. What do you think the problem may be?
Posted on Feb 18, 2008
  • 668 Answers
SOURCE: replaced wd-62525 lamp, picture dim
Cleaning the mirrors will not increase the brightness much. I would double check the lamp setting in the Menu and also the setting of the picture and brightness settings. Many times these are adjustable independently for different inputs. Besides this, I would look at the Ballast and or the Power Supply to cause the problem. I would recommend a professional to look at it if it is not correctable from the Main Menu of the set.
Hope this helps,
Skyassoc
Posted on Jul 17, 2009
  • 64 Answers
SOURCE: Can you help me find a parts kit for the WD 62525?
I cannot verify the integrity or value of the kits...here is one link however:
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
This may help...
Posted on Aug 03, 2009
  • 213 Answers
SOURCE: my wd 62525 has a blinking timer light and wont power on
do the timer come on at all whean you plug it in do you hear kind of noses? if not take it to a sevice shop
Posted on Nov 30, 2009
Flashing green light
you can buy a DM or Power kits from tv repair. i changed the capacitors on both of mine but it has not fixed the problem. Same WD-62525 it may work for yours.
Dec 27, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Wd-62525 dlp: I get the following message: TV
how long does the set run before you get the message?
Dec 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD62825 Mits DLP ~ Lines in picture
the DM board and the FMT board need to be repaired. it is not the 4 caps. it will cost about $250.00 plus shipping. go to
www.tv-techs.com
Nov 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62825 vertical lines, blue snow, picture jumping
I have the same problem with my tv, my tv tech said mitsubishi knows of the problem and knows how to fix it, but it would cost me 700.00 plus his labor to take out the chassis and send it in to mitsubishi, plus I would be without a tv for up to a month. this is b.s.
Oct 30, 2008 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 part #915P026010
Part number ( #915P026010 ) you wrote is called Lamp (bulb) of Mitsubishi DLP TV.
This part is available on Parts Store approx on $200
Thank you.
Oct 07, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
Jul 28, 2008 | Televison & Video
T.V. Problems
sounds like the capacitors on the FMT or Signal PWB need to be replaced.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Jan 05, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
116 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
