When I put a DVD or CD into my player (which is a 5-Disc), it makes a grinding/high-pitched whine and will not play the disc. It just tries to go to the next disc. I tried putting a lens cleaning disc in it and it did the same thing.
  • kilgoretrout Oct 15, 2008
    I won't be able to try it out for a couple days, but as soon as I can, I'm gonna try that.
    I'll let you know how it goes.
  • 128 Answers
I think you have a defective lens there's an adjustment right under the lens which would require a precision screw try to adjust it by turning it a little at a time and check if it reads after every turn. for dvd players there are two adjustments and one for cd players.if this doesn't solve your problem then you have to replace the lens of your player
Posted on Oct 15, 2008
I have just the dvd player, the player keeps ejecting the disc and not playing it
Could be lots of things, but here are a few easy ideas:
1) Is the disc Blu-Ray? A regular DVD player can't read Blu-Rays.
2) I think all DVD players can read CDs, but if the disc you're putting in is a CD, maybe that's the problem.
3) Maybe the disc is dirty. Wet the disc, wash it with dish soap (or hand soap, then rinse it clean and dry it off. You can use a cloth or a paper towel for washing/drying. When washing and drying, make motions across the disc from the inside hole to the edge; don't swirl around the disc.
4) Maybe the disc is not the same region as the player. https://en.wikipedia.org/wiki/DVD_region_code
5) You've got a PAL (European) disc and an NTSC (American/Japanese) player.
Aug 02, 2015 | LG Televison & Video
Why my dvd wont play on my player
Does that disc work on other players? Do other discs work on your player?
If you tell us more about the player, the disc, and what happens when you try to play the disc, we'll be able to make better guesses about what the problem is. Can you play other discs? Does that disc work in other players?
Not having specifics, here are some ideas, in the order in which they popped into my head:
1) That's a Blu-Ray disc and you have a DVD player.
2) The disc is dirty. Take a wet cloth (or paper towel), put a little dish soap on it, and gently swipe the shiny side of the disc from the center of the disc to the edge (don't wipe the cloth around and around the disc). Rinse the disc with cold water. Wipe with a soap-free wet cloth. Rinse again. Wipe with a dry cloth (or paper towel).
3) The disc is scratched. Some players handle scratched discs better than others. There isn't much you can do here. There are kits that can repair some scratches, but the kits aren't free, and they don't work a lot of the time.
4) You are putting the disc in upside-down. The side with the printing on it has to face up.
5) Your DVD player is dirty. Open the disc tray and blow as hard as you can into the player. Try not to blow any spittle into the player.
6) Your DVD player is broken.
7) Your disc is NTSC (Japan/US) and your player is PAL/SECAM (the rest of the world). Or vice versa.
8) There is some thing about region codes which is some kind of copyright protection scheme that means not all discs will work with all players.
9) Your disc is a CD, not a DVD. (I think most DVD players can play CDs, though.)
10) Your disc is DVD-ROM, meant to be used in a computer.
Mar 02, 2015 | Televison & Video
How to repair dvd player v zon says wrong disc
Hi Vzon DVD Player,
Before you fix anything, you need to troubleshoot the problem first to know what needs fixing. Since DVD players can play different kind of media formats like Audio CD, VCD, mp3, etc, please try the following
1. Turn on the DVD player and set the program to DVD. some player needs to be setup due to multiple functionality (can play mp3 on flash drive, etc..)
2. insert different Media CD as mentioned above if your player will play them. (if they play, try to insert the DVD you want to play)
3. Try different DVD disc
4. If all the above don't work, try to clean the laser head using the standard disc cleaner.
5. retry the DVD disc
6. If the player still don't play your DVD, probable issue would be the laser head or the disc motor.
7. Please bring them to you nearest Electronic repair shop for further assessment.
Good luck and thanks!
Aug 20, 2011 | Coby TF-DVD7107 Portable DVD Player
Solutions to incorrect disk error c105 & c104
Hello gjbrokke,
First make sure the disc is compatible with the dvd player (CD-R+ , or CD-R - )
Second make sure the region code of the dvd you burned is compatible with the dvd region settings on your dvd player.
One of those two are preventing the disc from playing in your sansui player.
May 19, 2009 | Sansui VRDVD4005 DVD Player/VCR
Try to play a dvd and the DVR 1600 starts to make a high pitch noise and will not play dvd.
If the noise comes from the cd tray, it is probably a bad spindle motor (the motor that spins the disc).
Aug 20, 2008 | Cyberhome Televison & Video
"no disc" message
you should be cautious of what you do. every time you put a cd/dvd make sure your disc is clean, no scratches, no damage, no dirt, and no STICKERS sticking at the disc.
well if the problem just occurred inside your cd/dvd player, all you can do is to clean the optical eye with cloth and water and rub it at the eye(don't put to much water, just soak the cloth a little bit and don't put too much pressure against the optical eye)
if does it again adjusting the sensitivity of the optical eye would help, if still, you have to order a new optical eye though or buy a new cd/dvd player.
just be carefull of what you put inside your thing.ok?
have a good day and take care.
Mar 29, 2008 | Sony DVP-NS575P DVD Player
As a CD player - shuffle/random?
The point of buying a 5 disc CD/DVD player is that you can let the machine play randomly through all 5 CD . Where is that button ?
Dec 10, 2007 | Venturer SVP580 Multi-disc DVD Player
Dvd player model dz111
there is a disc cleaner disc and a cleaning solution. put the liquid on cleaner disc and insert it.play for some time. now put a new dvd or cd and try
Oct 24, 2007 | Audio Players & Recorders
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
