Question about Steinberg Cubase SX3 (502010600) for PC, Mac
Can't load samples to HALION ONE ON CUBASE 4
Cubase 4 is loaded !
When I right click on HALION ONE to loacate the contain of his samples,
Cubase pop up a message telling me that a hard error occures, you should save your work with another name and restart Cubase.
When I close Cubase another message refer to AUDIOPRIMITIVE.OPT
So for the mement, I can't load Halion One Samples.
Thank you in advance for your help.
mappbrown
mappbrown@yahoo.fr
2 Suggested Answers
SOURCE: Cubase 4
During your computer's boot sequence, watch for a notice telling you which key to strike to ENTER SETUP. This will take you to your BIOS management. Find and disable Intel SpeedStep, C1E, or EIST, or related PowerNow! settings on AMD processors. These power saving settings are designed to slow down or shut down one or more cores of multi-core processors during times when the operating system thinks that the processing power is unnecessary, but running advanced DAW software such as Cubase draws power at very near the full system capacity, and it takes a long time to reboot the temporarily suspended processor cores. During this core reboot lagtime, Cubase is often deprived of the processing power needed to route audio signals through its complex internal bussing system (Steinberg's patented VST system link), and this power loss causes it to crash. If you disable the SpeedStep settings in your BIOS, you may notice a very gentle rise in your electric bill, as your computer's processor will be running at full capacity all the time, but you can always re-enable SpeedStep when you're not planning on recording anything.
Posted on Feb 07, 2011
Have bought but dont have cd with drivers and cubase le for lexicon lambda
You may find a link for LE . . Free down load with key & dongle emulator . . Best luck . .
Sep 12, 2013 | Steinberg Cubase Studio 4 Full Version for...
Cubase 5 some HALion one plugins wont work
are you sure you downloaded or got the exact plugin? If you had error while downloading... try redownloading or better still get it from a friend. Try and upload the plugin properly. hope this help
Aug 05, 2013 | Computers & Internet
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
Audible click/pop when starting program. ASIO
Due to the DIGI001 ASIO settings, the HALion engine and program should be used as a plug-in (VSTi) in your master DAW, (i.e., Sonar, ProTools, Cubase, etc.) and it should fix the problem. Ensure that your drivers are updated and direct all signal traffic to the input device that is shared throughout your system or simply reassign your "patchwork" through the main DAW as mentioned above.
Peace
DJDIRTYDISHEZ
Oct 12, 2009 | Steinberg HALion 3 Full Version for PC,...
0404 installed but cubase vst 5.1 will not load it stalls when loading vb-1. I had the same problem with an auditgy card any ideas on how to fix the problem? Geoff
vb-1 is a cubase virtual instrument this is where cubase was stalling, When i uninstalled cubase i went into the vst plugin folder and saw the folder vb-1 [virtual bass] I read the text file within and it told me to copy the dll files within into the active vst plugin folder. when i re installed cubase all was well. I have been using cubase for years and did not have this problem until i installed the e-mu 0404 pci card, or the audigy card
Aug 05, 2008 | E-Mu 0404 Bundle Sound Card
Cubase 4 Error Message
Same problem with audioprimitive.opt on Cubase 4
Mar 21, 2008 | Audio Players & Recorders
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Nuendo/Cubase sound cuts off
I chased this same problem with a friend's laptop using Cubase. Additionally, he had several recurring pops at high end, in regular intervals, with 23 seconds of trouble free gaps in between incidents. Eliminated hardware problems, so I contacted some Cubase user groups and they indicated their older software was not compliant with the newest hardware... in other words, they suggested he buy a newer version.... He did (gasp, sticker shock... the horror) and the problem disappeared. Might be all that is wrong for yours, if your desktop has newer hardware and older version of Cubase.
Jan 31, 2008 | Intel Steinberg Nuendo AudioLink PCI 96...
Loading problem emu1616
First up, I am no expert, but hope I can help.
I think that it is just a matter of following the installation procedures which EMU describe in the booklet.
When you insert the card for the first time, do not install using the hardware wizard.
Instead exit out of it and insert the cd, which will run a seperate install procedure (if autorun is enabled).
During the installation, a splashscreen will pop up (at around 45% complete) saying that the driver is not signed. Choose 'continue anyway'.
This should take care of the digital signature issue.
After this, there might be a problem with the cardbus controller.
This is highlighted on the EMU website.
Thats the problem which I am struggling with and hope someone can help out ..
Dec 10, 2007 | E-Mu 1616M Sound Card
Steinberg Cubase SX3 (502010600) for PC, Mac Logo
218 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Donald Currie III
Level 1 Expert
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
