Error: “HP Cue Scanning Flow component has encountered a problem and needs to be closed”.
The problem is caused by HP software not installing the file path to the scanner correctly in XP, so if you run a registry cleaner such as RegCure it will delete the file path.
OS: Windows XP.
If you encounter this error message please follow the steps below:
1. Go to registry by clicking on Start/Run then typing in regedit and hitting enter.
2. Go to HKEY_ Local_ Machine\Software\Hewlett-Packard\DigitalImaging\
3. Click on the Digital Imaging Folder and in the Right Hand Side Pane and check if the String Value “ProfileWritePath” is present and Value is set to %APPDATA%\HP\Digital Imaging\Data\Destination
4. If the Sting Value is not present right click and then click on new and then click on String Value Name it as “ProfileWritePath” and then right click on that and click on Modify and make sure that the value is set to “%APPDATA%\HP\Digital Imaging\Data\Destination” and close the registry editor.
5. Then go to My computer C:\Documents and Settings\All Users\Application Data\HP\Digital Imaging\Data and check if the Destination folder is present. If not create a new folder and name it as “Destination”.
6. If you are unable to locate the Application Data folder under All users, click on Tools and then click on Folder Option. In the Folder Options Window click on the View tab and under Hidden Files and Folders make sure that “Show Hidden Files and Folders” is checked and then click on Apply and then click on OK..
7. Then Make sure that the same that the HP\Digital Imaging\Data\Destination folder is present under all user profiles Application Data folder.
8. Run Regcure and after the scan check the file/path errors and tell it to ignore the HKEY_LOCAL_MACHINE\SOFTWARE\Hewlett-Packard\digitalImaging ProfileWritePath= C:\Documents and Settings\ (whatever your file path to the destination folder is)
Now it should run flwalessly even after you run regcure.
For other registry cleaners I'm sorry but you will have to find out how to tell your cleaner not to delete the erroneous file/path error.
Graham Sept 13th 2009.
Hp fixed it
It has the green light flashing but won't scan
how did they fix it..i have the same problem.
i have the same problem! :(
won't scan
Mine won't scan either. HP didn't fix it!
green light flashes but dosent scan :S
anyone know how to fix?
i also have the same problem please can anyone help me im in real need of it..
not scanning
