Dell SP2208WFP Flat Panel Monitor goes straight to power save mode
I have had my computer in "hibernate" for about two days when I came back my monitor wouldn't come out of power save mode and was left staring at a blank screen. I checked and rechecked all of the cables and cords...unplugging, replugging, changing USB locations, power off, and power on for about an hour. My last experiment was to unplug both the monitor and the tower from the outlits for about 2 minutes and...volia, the monitor is working again.
Yay, problem fixed, right?
Well, this isn't the first time. I don't remember how I got it fixed the first time because the issue lasted about 15 minutes (this time 1 hour). If anyone can shed some light as to why this happens or how to prevent it from happening again, it would be greatly appreciated.
  • 3 more comments
  • lindsseeyy Oct 15, 2008
    When my computer is in hibernate mode I have to press the power button to awaken it, clicking the mouse or hitting the keyboard doesn't wake it up.
    When it's in that mode the monitor lights are orange indicating it's on but in power save. When it's working properly the lights are blue.
    I have also tried an old monitor and it worked properly.
    The light on the monitor stays a consistant orange when the computer is woke up.
    You're wonerful, thank you for taking the time.
  • Fran Bednar
    Fran Bednar May 11, 2010
    When the computer awakens, Does the power light on the monitor turn
    blue and it doesn't work or light up or does it stay orange ?
  • Fran Bednar
    You Say Computer and monitor go to sleep.
    What does the power light on the monitor do when it does >
    Then what happens to the power light on the moniotr when you hit the keyboard or move the mouse to awaken the computer ?
    Did you try a different monitor to determine if it is the monitor or the computer ?
    Novelist:
  • 159 Answers
If the monitor is not turning blue that means it isn't picking up on the signal that is coming to it.
Pushing the power button on the monitor should make the monitor work and give you a no signal note if it isn't getting signal.
If it won't power on with its own power button you maybe having a low voltage problem in the monitor itself which isn't giving it enough to fire up after it has been sitting.
Just a note these monitors use and make power even when they are off, unless they are unplugged.
I'm thinking along this route also because when you said you unplugged it for a while that it did turn back on.
Only way to verify it, is to double check the monitor on another computer. and if it is the same then it will have to come apart.
Power issues are very common in lcd monitors, Lots of heat in a confined space. The bigger they get the hotter they get.
You would think they would have incorporated internal fans in these by now. But then they wouldn't sell as many !!!
bammbammfran
Search and you shall find me !!
Posted on Oct 15, 2008
  • Fran Bednar
    Fran Bednar Oct 15, 2008
    If you decide to rip it open to see, send me a picture of the power board.
    I may be able to see the problem.
    bammbamm@ptd.net
Pc monitor will not come out of hibernation
This may work for you it did for my son, Open control panel go to power options. set your pc to home/ office or what ever you use it for even always on if you like. Also at the top there is a hibernation icon open it make sure it is unchecked. You can also find the download for your monitor and see if there are any updates get them. and open up the file update,it there are any. some have an option for all kinds of settings display and such. Good luck
Oct 08, 2012 | Dell 22" SP2208WFP Widescreen Flat Panel...
Power Saving Mode problem using the DVI input. VGA input Ok.
try the display on another computer, if the display does the same thing on another machine, then its definitely a problem in the display not in the computer drivers or bios.
Sep 21, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 22" monitor goes black
Your monitor probably has bad capacitors now. Bring it to a local electronic repair shop and have the monitor tested. They can easily replace any bad capacitors.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | Dell 22" SP2208WFP Widescreen Flat Panel...
Monitor goes into sleep mode and won't come back
go through control panel to Power Options, switch off the options to sleep/hibernate.
Oct 27, 2009 | Computers & Internet
SP2208wfp monitor goes into sleep during videos
Assuming you are using Win-XP, go into control panel, Appearance and Themes and Choose a screensaver. There should be an option below the screensaver choice to adjust Power Saver settings.
Sep 19, 2009 | Dell 22" SP2208WFP Widescreen Flat Panel...
How do I get a monitor out of hibernation mode? It is not responding and did not reset when I rebooted.
Try using the power button, which usually takes the computer out of hibernation. Also, the mouse and keyboard can sometimes wake the computer from hibernation as well.
If the computer is still stuck in a hibernated state, hold the power button in for about 5 seconds so the computer fully shuts down and power it back on.
Good Luck!
Aug 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Dell SP2208WFP hibernation
Hello there:
right click anywhere on a blank area of the desktop and go to properties go to screensaver and click on it now and the bottom right of the screensaver page will give you power options just open it up and you will see power options this page lets you choose how long before the screen and the harddrive turns off if you want it to never turn off under the time choices for the devices just go to never at the verry bottom of the time choices next took at the hibernation and click on it and set is as you would like it if you turn it off the computer will never go into the standby mode
i hope that this is really helpfull for you
please dont forget to rate this solution that i have provided
best regards michael
(USN) RETIRED
Aug 05, 2009 | Dell SP2009W 20 in. TV
Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 05, 2008 | Dell 21" M1110 .22DPI 1600x1200 *SUPER...
Power Save Mode Problem
under bios menu look for ACPI function and disable it. Should help same under device manager.
Nov 26, 2007 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Computers & Internet Logo
1,631 people viewed this question
David Payne
David Payne
