My printer will not print from the laptop to the officejet7210 printer
    Genius:
  • 1,605 Answers
Did you install the printer driver on the laptop??
laptop need to know what type of printer and all the setting.
go to printer and faxes see if the HP office jet 7210 is in the popup.
if it is in there try to send a test page to the printer via wire connection.
Posted on Oct 14, 2008
Wifi laptop will not print to printer - not a wifi printer
Check if the printer has a wireless option. Actually this issue is complex. First thing first, you can print wirelessly from your laptop within the WIFI range in a case that your printer do have wireless on in. It is impossible to print wirelessly from the wired printer through LAN.
One thing, I guess you don't have a wireless router. You need to have a wireless router like LINKSYS that is easy to setup then try to connect wirelessly to the wired printer. There I am not too sure if your can do a printing option from your laptop wirelessly.
Lastly, check if you have a ROUTER and need to set it up on your laptop and on the network LAN. You may now have a NETWORK printer in this regards. Thank you.
Oct 06, 2009 | HP Compaq Presario V6000T Notebook
I have a Toshiba Laptop that wont work with any printers
have you checked the paper settings that the printer prints? often the printer has letter format as first print options, and then it doesent work. you need to change it to A4 in printer settings.
What happends when you trying to print ?
Sep 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
My officejet7210 all-in-one, not working . i shut it off to checjk all connections, i had to to move the printer, now it wont turn on. I've pushed the on button quickly, held it. no go. any ideas?
hi, lets try some reset on the printer but before that make sure that the printer is directly connected to the wall socket and there is no power surge protector connected now place your hand on the the power adaptor of the printer and check if the adaptor is heating or not if its heating then proceed further if not then there is some problem with the adaptor
now connect the power adaptor to the printer and then try turn on the printer if its not turning on then press and hold the power button for 10 sec and then remove the power cable from the printer now keep pressing teh power button and after 10 sec reinsert the power cable and then release the power button
still if the printer is not powering on then press the # and 3 button on the printer and then while pressing them remove the power button wait for 5 sec and then replug the cable while pressing the buttons
now try to power on the printer if not powering on still then try the above step using the # and 6 buttons if till face the problem then the device needs service
Aug 29, 2009 | HP Officejet 7210 All-In-One InkJet...
Printer status says offline, and we can not print on laptop
Hi!
If you're offline with the printer, you definitely won't be able to print.
I'm assuming you're using Windows XP here. Most Windows products will be similar...
On the laptop, click on the Start button, then Settings, then Printers and Faxes. Find your printer in the list, right-click on it and click "Use Online" or uncheck the "Offline" box.
Good luck! Remember to rate the solutions!
Aug 10, 2009 | HP Officejet 6500 Wireless All-in-One...
Lost cd for laserjet 1320 cl6 printer. installed
either the usb wire is getting loose in the new laptop port.or the port is faulty.press the usb wire tightly and then try printing keeping it pressed at the laptop side and printer side too.with some bodies help. check out.
Jul 12, 2009 | HP LaserJet 1320 Printer
Cannot print from laptop to printer using wireless print server
This is probably the Software Firewall on your laptop
you should probably tell your firewall software that you have an internal network (Laptop-desktop-printer) you should add the IP range of the wireless network as a trusted network.
May 25, 2009 | Lexmark X3550 ALL-IN-ONE InkJet Printer
Dell 948 printer printing not finishing print jobs
Your printer loose documents:try to reset it ,unplug for an hour.
Or you might have interferences on your wireless :DECT phone, cell phone, or even an electric device who doesn't work propely, like tv, stove, speakers many things can parasites your connection...
If nothing does your printer as issues, think replacement...
cheers
Dec 19, 2008 | Dell 948 All-In-One InkJet Printer
Printing
If you want to print from your laptop to your desktop you can Share your printer on the desktop. Then when you add the printer on your laptop, choose "Networked printers" and as long as you are on the same network, it should show up
Apr 04, 2008 | HP Deskjet 6980 InkJet Photo Printer
jasbo
jasbo
