Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Digital camera problem
When i turn my camera on it is stuck on connecting to pc and will not do anything else
    Problem Solver:
  • 5 Answers
The Image Control PCB of your D40 is broken and it is replaceable
Posted on Oct 20, 2008
WHAT DOES AN ERROR SAYING NOT CONNECTED MEAN
On page 59 it says:
So I guess you did put in anUSB cable, but did not connect any device. It also could be something got stuck in the USB connector in the camera. Only blow to remove any debris, because you easy could break anything inside the connector. If you see anything in the connector try to emote it.
Jun 09, 2014 | Olympus ? Tough 3000 / Stylus Tough 3000...
Cannot turn my camera on...we took many pictures and the camera worked fine. now, when I turn it on to load the pictures on to my pc, nothing happens.
Maybe you camera battery power had run off? And this camera battery can't be charged when you connect it to computer. Anything help?
Dec 31, 2010 | Canon PowerShot SD960 IS Digital Camera
Shutter is stuck. when I turn the camera on the
Have you tried to gently coax it open with something like a toothpick?
Jun 13, 2010 | Panasonic Lumix DMC-LZ5 Digital Camera
Camera won't show anything but black in the screen ... Or looking through the eye piece (canon S3 power shot) think the cold weather caused it
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 14, 2010 | Canon PowerShot S2 IS Digital Camera
The screen is black, i cannot see anything on the
First thing to check is to make sure that you didn't just accidentally press the DISP or DISPLAY button on the back of your camera, manually turning the screen off. Press the DISP button once with the camera turned on. If that didn't correct the problem, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 10, 2010 | Canon PowerShot SD500 / IXUS 700 Digital...
Can this camera be RESET? Camera Stuck in Clock set mode.
If you are familiar with camera repair then apart camera and check navigation switch board is intact with main board of camera.
That is only reason of switches no operation in this camera.
Feb 03, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Photo's won't upload!
Try it on different pc to make sure it's not the camera, if it works on different pc, uninstall all the usb drivers in device manager then reboot
Mar 05, 2008 | Vivitar ViviCam 4345 Digital Camera
Camera won't connect to PC.
Hello!!
install the drivers of the camera again ...
Dec 28, 2007 | Samsung Digimax D53 Digital Camera
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
57 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
