Question about Radio Communications
Radio Shack Pro-26 Scanner Not Receiving
This radio has worked fine for years, but, lately, my reception seems to have dropped to practically nothing. I tried swapping antennas with another radio I was repairing for someone, and that didn't help. Even with the other radio picking up a strong signal, mine gets nothing on the same frequency.
Any ideas?
  • Anonymous Feb 23, 2009
    no sound
  • 204 Answers
Hello dino, It sounds just offhand likethe scanner is just getting tired. Maybe a componant failed or changed value inside on the circuit board, that will change the whole setup. It will no longer be fine tuned for the correct freq. range. Hope this helps,,, I know it's not what you wanted to hear.Mechanic
Posted on Nov 01, 2008
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Listening in since the 60's
Nov 11, 2010 | Radio Communications
Problem with PRO-2066 scanner not receiving local 800mhz Motorola trunk system II. It does trunk with the current data channels used (showing the ---- line) but I only hear transmissions on freqs ending...
It is difficult to explain in simple terms but I will try.
Google rebanding.
Some radios can have their firmware updated but I don't think your PRO 2066 can.
Channel numbers and frequencies preprogrammed into your scanner have changed over the past few years.
When a data signal says go to channel X that channel is now Y, but your scanner is still looking for X
Hope this helps
Aug 21, 2017 | Radio Shack Pro-97 Handheld Scanner
Pro-164 scanner stops receiving when Motorola talk-ids are progra
I had to buy the Radio Shack USB cable 20-047 and install
the driver for it and then I downloaded a program named
"Win97" from the website as listed
on page 21 of the Pro-164 manual. The cable costs
$34.99 and with tax you are looking at about $37.88.
The "Win97" software must be registered for it to work
after a 30-day free trial period. That's approx $25.00.
This is the ONLY WAY to go !! You put in everything
on the software GUI and then upload it to the PRO-164.
Works like a champ !!!!!!
Dec 31, 2009 | Radio Shack Pro-97 Handheld Scanner
How do i unlock a radio shack 164 hand held scanner and how do you program the scanner
The PRO-164 is a trunking scanner with many programming options, and attempting to detail the full programming procedure here wouldn't be practical. Rather, follow this link and you can download/print the full operating manual for your scanner.
Nov 15, 2009 | Radio Shack Pro-97 Handheld Scanner
Not picking up any signals
they have switched to a digital trunking system it costs about 1000 dollars for the new ones
Mar 21, 2009 | Radio Shack Pro-82 Scanner
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Greg Stevens
Aug 07, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio scanner not receiving
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
Feb 28, 2008 | Uniden BC248CLT Base Scanner
Motorola Trunking not working
If you are getting "cross over" on freqs, then you need to take it in and have it repaired by a pro. You have some bad parts inside and only with the proper electronic gear can you locate them. Plus it will need to be retuned.
Aug 03, 2007 | Radio Shack Pro-95 Handheld Scanner
Pro-95 dual trunk-tracking handheld scanner from Radio Shack
Firstly make sure the "squelch" is set as per the manual (link below) page 26. If that fails I suggest initializing the scanner to factory defaults as below:
Aug 01, 2007 | Radio Shack Pro-95 Handheld Scanner
Radio Communications Logo
413 people viewed this question
Top Radio Communications Experts
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
