Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Start relay problem
Hi There!
My start relay on my Kenmore is bad, it's melted, black, stinks and rattles. The original part I removed from the refrigerator is part number 2212194. I wen to Sears and they sent me parts 2188830 and 2188829. In the directions it tells me to use part number 2154697 but they didnt send that one. The two relays they did send have one less wire connection and different wire connections then the original. What am I missing? Any help is much appreciated! Thanks!
  • dalmobile Feb 14, 2009
    Hi - I have similar problem. I got start relay/overload switch combo 2154697. I need help in figuring out how to connect the red and white wires now.
    1. where does each wire go
    3. The start relay has three possible places I can plug the wire. They are marked #1, #2, #3, #4. On once side there are two prongs and the other side has only one.
    thanks.
  • 120 Answers
Ok jason 1st does your relay have the capacitor sitting on top if yes then open bag 282383 and use the one that has the same color dot on top of relay and good to go.
now if you have the one with capacitor off the the relay then open bag282382 and if you compressor rating is egy80 use 2187145 and if it is egy90 then use 2154697 now to use this type there is a white jupmer cable that you will have to connect to the whit wire because the connctor is different size ok red wire goes on the overload thats is the white part and the white jumper goes on the left side and the blue wire goes on the right side og relay that's the small black little box and that is all if you want to use the cover you can if not you dont have too . let me know if that helpfull ok
Posted on Oct 15, 2008
. kenmore side by side blows warm air, after
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 30, 2011 | Kenmore Side by Side Refrigerator
Compressor does not start all I get is a clicking sound when it tries to start model#970-65832c purchase July 2004
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it's bad is to shake it. If it rattles, it's bad and needs to be replaced. If not, most of the time it's ok. But rather than saying the compressors bad, you might want to replace it anyways because it does not cost much. A quick check on the compressor is to remove the start relay. You will see 3 pins connect a multi meter set for continuity. You should have continuity between any of the 3 pins. If you do not the compressor is bad. Also check from each pin to a good ground on the cabinet. There should be no continuity if there is the compressor is bad. If you replace it and it doesn't work then the compressor is bad and you'll need to call a repairman. (Note that compressors are very costly and are normally not worth fixing).You can enter your model # at Refrigerator clicking for diagrams and illustrations or to purchase a start relay. A 3 in 1 start relay will also work fine. All parts come with installation instructions. Not all models are available.
Mar 21, 2011 | Kenmore Refrigerators
Model: 253-54743301 Kenmore Refrigerator\r\nlost cooling in both Refrigerator and Freezer
Jan 07, 2011 | Kenmore Refrigerators
I smelled a strong odor, like rubber burning yesterday, and heard a small beeping, like something was trying to go on but didn't and noticed this morning that the freezer is defrosting, everything is...
it sounds like the start device failed,unplug the machine so you don't cook the pins on the compressor,pull out the machine and remove the back bottom panel and on the compressor you'll see the start device,remove the clip holding it onto the compressor and when you have it out shake it,if it rattles you'll know it's bad and you'll probably be able to smell the burnt stink on it,the part number is 2304884 and it's around 40 bucks,let me know how you make out
Oct 17, 2010 | KitchenAid Superba® Architect® KSRP22FSMS...
Compressor does not want to start.
If the compressor will not kick on what you have is either a bad compressor or a bad starting device. Generally the unit will try and start and after 8 seconds or so you will hear a loud tick. That indicates the relay is bad. If the compressor is bad it will usually make a loud humming noise.
The start device is plugged into the side of the compressor. Unplug the frig. You can simply take off the wires to the start device (remember where they go!!!!!) and pull it off. You have two piece, the overload and the relay. The relay is the piece that is most likely the problem. Some machines will have these put together in a white plastic block. You can shake this entire piece and if you hear loud rattling it is broken. Sometimes the relay is visibly burned and blacked where it plugs into the compressor. Anyway, if you do not have this white plastic relay/overload combo, the relay is a brown square shaped plastic piece. Shake it and see if you hear rattling. If not, chances are very good the relay is ok, and the compressor is locked up.
Compressor changes are expensive and unless the frig is extremely nice and cost a pretty penny, they aren't worth fixing. Relays and overloads should not break $100 for the parts, and any tech should be able to change one in under 10 minutes. So if it's a relay fix that puppy! good luck :D
P.S. In a RARE occasion the frig may use a capacitor, and the capacitor may be bad. The only way to check is with a multimeter or replace the capacitor and see if it fixed it. This is highly unlikely and therefore not checking from the beginning.
May 29, 2010 | Kenmore 72232 / 72234 / 72239 Bottom...
Our Kenmore Elite Side by Side refrigerator stopped cooling. I replaced the start relay device like suggested (it rattled). I put on the new one (no rattle) and the compressor still would not start. Just...
On occasion your compressor windings can be damaged from the starting components going bad. Or like you said the comp is locked up which in turn damaged the starting components from them continually trying to start the compressor. Either way it sounds like you have a bad compressor which will probably be more than you will want to spend. You would probably be looking at 600 bucks or more with parts and labor for a new compressor. Hope this helps _MJ_
Apr 27, 2010 | Kenmore 73503 Stainless Steel Bottom...
Refrigerator and freezer are not cooling. Ice is starting to melt in freezer. I hear a clicking sound. Light works.
You can start with replacing the start capacitor and relay to see if the compressor will run again, but you have about a 50 -50 chance that the compressor has gone bad and will need to be replaced....
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 07, 2010 | Kenmore 53632 / 53634 Side by Side...
Kenmore elite side by side stopped cooling fridge and freezer.niether side is cold both sides are warm can hea fan running but no cold air everything has melted
replace the rtc overload contactor located on the compressors side body,just unplug off the compressor and plug in a new rtc,it supplies start and run power to the compressor,when its removed,shake it,if it rattles its another sign its bad
Mar 05, 2010 | Refrigerators
Kenmore side by side #50562991
The black pod is the compressor and the switch on the side is the compressor start relay. You either have a failed relay or a locked up compressor.
Most likely it is a burned out relay.
Unplug the fridge and remove the relay from the compressor.
Shake it. If it sounds like a lot of loose pieces are rattling around in it, it is burned out.
Be sure you replace it with the correct replacement part. A "fit-all" relay may work for a while then cause the compressor to fail.
Your model number has 106 in front of it. You will need to know that when looking up or ordering parts.
Post back if you have any questions.
Nov 11, 2007 | Refrigerators
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
1,059 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
