Question about Canon Office Equipment & Supplies
Faxing error Hi I keep getting a tx error 0080 on my fax machine. I know other peoples faxes are going through to her but mine I keep getting this error. I have looked over everything and still get this error. I have a Canon MF3200 I am going right threw the phone line not the computer. Any help would be greatly appreciated. Thank you
  • ladylisa1 Oct 15, 2008
    I did do both of the things you said. I had the phone jack with a phone it's working and my other end is in the line jack. :( The 0080 error says that the recipients machine did not respond within 35 seconds is what the error says. But she said she is getting other peoples faxes. ??
    I have verizon landline phone. I have comcast for internet. I am thinking it must be at her end but why she gets other peoples and not mine?? Thanks again. Lisa :)
    Genius:
  • 2,120 Answers
Plug a regular phone into the wall outlet and listen for a dial tone.
Make sure the phone cord is plugged into the LINE port of the fax machine.
Posted on Oct 15, 2008
  • Leroy Elliott
    Leroy Elliott Oct 15, 2008
    Do you have DSL or any other kind of digital phone service?
  • Leroy Elliott
    Compatibility is a four letter word.
I keep getting comm error 242 when people are faxing to me
The "sender's" fax machine is attempting to RECEIVE a fax. This happens because they don't have the document fully inserted into the scanner before dialing. (According to HP's error code listing for "comm error 242" - http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=buu02549) This is not a problem of a bad connection. Bad line condition codes are 223, 224 and most of the codes starting with 23.
Apr 28, 2010 | HP LaserJet 3050 Printer
Hello i keep faxing and it says gthat it is not
Check the phone number of the fax maching you are trying to send to.
Call the fax number with your phone (not fax machine) and confirm that a fax tone sequence is trying to sync.... If you get a "Hello" .. then you have a wrong fax number...
Sep 29, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Faxes won't complete transmission
those noises you hear are line noises via your phone line, not machine related but they wreak havoc on faxing. first you need to replace the actual line connecting the fax machine to the wall. If this doesn't fix the problem then have your phone lines tested. also make sure your machine is set for digital or analog service, depending on which you have. Good Luck.
Sep 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error 441*
Error #441 is caused by poor line quality accross the telephone line or faxing to a non-compatible fax. Try faxing to someone else as a test, if it still happens, try moving the fax to a different phone jack. You can also try faxing at a differn't time. Also try replacing the phone cord attached to the fax.
In all cases it's either phone line, phone cord or non-compatible machines (old fax on receiving side).
Aug 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Faxing
did u try to do a hard reset to clear this error?
if nt try it please
Jun 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
437 people viewed this question
old marine
old marine
