Samsung TXM3297HF 32" TV
Problem for Samsung TXM3297HF 32" TV
Samsung TXM3297hf
By vijaymadia on Oct 14, 2008
No vertical Deflection
Solution #1
posted on Oct 15, 2008
Not Rated)
Abrsvcs
Rank: Guru  Samsung Televisions & Videos  Expert
Rating: 88%, 1859 votes
Look for a small flat Ic attached to a heatsink with about 11 pins. That should be the vertical IC. Resolder the pins first. If that fails to resolve the problem, replace the IC and update this note with your results. The IC should be marked LA7837 or something similar.
Dan
Was this helpful?
Yes
No
Popular Solutions for Samsung TXM3297HF 32" TV
Questions and Unsolved Problems for Samsung TXM3297HF 32" TV
Do you recommend Samsung TXM3297HF 32" TV?
Answer
Answer
Samsung AA26-00069A (FUJ-29002C) has two High Voltage connections. What goes where?
Answer
I have a 42 in Samsung flat screen and the secondary fan is not working. Where is the 2nd dary fan... (More)
Answer
I am unable to retune the freeview channels on my 32" crt samsung tv which means i can't add... (More)
Answer
The tv will play for about 30 mins. and then cuts off. Let the tv sit for an hour or more and it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
in , AR
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
