Question about Kenmore 43142 Front Load Washer
Kenmore Dryer Model #110.62212100-"NO HEAT "Problem
I bought a 279816 Thermal Cutoff Kit,the Instructions are so confusing,can you give me a simple & easy to follow instructions to install it?
Powerman
  • 68 Answers
SOURCE: Kenmore oven clock control installation instructions
Your prpblem is not the control, it is a short circuit in the ribbon cable between the keypad and control. You can find my fix at:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success.
Please let me know if this works for you. Email me at:
hutchipop@yahoo.com
Posted on Nov 22, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore dryer (electric )
You will need to UNPLUG the dryer and remove the back panel to access. The heating element is located inside the heater box on the right-hand side of the dryer (facing from the back). Simply disconnect, the wires leads and remove the mounting screws to remove.
Now...you mentioned removing the thermal fuse. Did you check the thermal cut-out or the hi-limit thermostat? These components are small silver disc-shaped devices mounted on the heater box assembly. As you are facing the back of the dryer, the hi-limit thermostat is located near the terminal connections of the heating element. The thermal cut-out is located farthest away from the heating element closer to the top of the heater box. Usually when you have a no heat problem, it the thermal cut-out, hi-limit thermostat, or heating element that goes bad. If the thermal fuse is bad, you generally have a dryer that not only won't heat, but won't even turn on. I hope I'm not confusing you. In a nut shell, there's a difference between the thermal fuse and the thermal cut-out. If you had large accumulations of lint in your dryer, I would bet you have a blown thermal cut-out.
If you wish to check the parts listing yourself to make sure you have the correct parts, go to searspartsdirect.com, type in your model number and look under the "Bulkhead" heading. The thermal cut-out kit is what you need to order for a no heat problem. It's listed as item #1 (part #279816). This also includes the hi-limit thermostat. It is recommended by the manufacturer to replace BOTH of these components at the same time. The heating element is listed as item #14 (part #279838).
Look under the "view diagram" heading and you can see where all these components are located, using the exploded view of the dryer assembly. The thermal fuse you mention is listed as item #59 in the drawing and is located on the air baffle housing.
This is still an easy fix. I just want to make sure you're identifying the correct parts. I don't think you want to purchase parts you don't need.
I hope this helps you. If I've managed to confuse you, please post back with your questions and I can guide you in the right direction.
Posted on Apr 16, 2008
  • 62 Answers
SOURCE: Kenmore 80 Series Dryer - No Heat - Thermal Cutoff Kit 279769
that therm. will actually come off the heating element part, it is always good to change both, I use a small screwdriver to get it off
Posted on Nov 09, 2008
  • 115 Answers
SOURCE: HOW TO REPLACE A THERMAL CUTOFF ON ELECTRIC DRYER
you will need too take off your back panel of your dryer and the heater is on your right the thermal cutoff is on the left of the heater housing at the top and then there is a little white thermal cutoff on your blower housing in the bottom left of the dryer now if this is not how your dryer looks let me know cause there is several different style of kenmore dryers but this is the most common one
Posted on Dec 29, 2008
mastatech
  • 478 Answers
SOURCE: need to replace thermal fuse on kenmore dryer 110.75924401
This fuse is located on the back on the wind tunnel exhaust.
Posted on Mar 14, 2009
What number thermal fuse and thermostat will work on kenmore elite model 11o 23032 dryer
thermal fuse 3390719
Thermal cut off and high limit kit 279816
Operating thermostat 3387134
Jan 22, 2017 | Kenmore Dryers
How do I install part #279816 which technician said replaced 3399693?
Hello. Here is the link which includes a video on how to replace the thermal fuse kit for the dryer. http://www.appliancepartspros.com/whirlpool-dryer-thermal-cut-279816-ap3094244.html. I hope this helps you.
Aug 24, 2015 | Dryers
Why won't my kenmore dryer 970-c85092-00 heat?
check the heating element to see if the coils are still intact (not burnt or brake). if it is fine,then check the T-STAT and the T-CUTOFF switch. one of those is your problem. if it is the T-STAT or T-CUTOFF, replace them both, they are inexpensive and easy to replace. here is a link to a video that explains this fix thoroughly. i think you will find it helpful.
Whirlpool Kenmore Dryer Repair Won Heat Test Fuse Thermostat 279816 or...
Jul 23, 2014 | Kenmore Dryers
Kemore dryer model110.67522600, checked continuity on heating element,OK, Thermal fuse OK,cutoff-tml ? Thermostat #3977767 no continuity.Thermostat #3387134 ?
Both the high limit thermostat #3977767 and the operating thermostat #3387134 are normally closed switches and should have continuity. These thermostats are usually replaced as a set because when one fails its often caused damage to the other. The part # for the kit is 279816 and comes with both and is cheaper than if bought separate
Sep 16, 2010 | Kenmore Dryers
How to connect dryer wires to thermal cutoff
The first thing I would like you to do is get your model number from the dryer, it is located near the inside the of the dryer door. you need to make sure you have the right heater and thermal cutoff kit. The manufacture has more than one type of heater and thermal cutoff kit out, (( some will not work with others ))... Call another parts store or sears and make sure you have the correct parts !!
Most of the thermo cutoff kits have direction and if they are not making scence then the chance of you having the rong one is good !!!!!!!
If you remove the thermal cutoff from your origanal heater and then look at how many conetion pins are left. The new heater and old heater should be the same.
The most common heater is the 2 conection. But they made one with three. and if you have the one with three, it has to be replaced with the same one !!!
Without knowing the model of your machine, I cant tell you how to wire your machine.
I recomend you use the direction that came with the Cutoff kit.
Aug 11, 2010 | Kenmore 62602 Electric Dryer
Should you have continuity on the cut off switch?
4239059.jpgcheck this out: If either one of these limits mounted aside the heat chamber check open the dryer will not heat but it will run. These come in a kit with both limits and both limits need replacement.
Apr 11, 2010 | Dryers
I am replacing the thermostat on my Roper dryer. Model number of dryer is RES7745RQ0. I went to a local parts supplier and I received the ''Thermal Cutoff kit'' with the part number 279769. The spade...
it may be 279816. it can also depend on what thermal fuse you are trying to replace.part # 3977393 includes both the fuses that go on the
heating element can
Sep 26, 2009 | Dryers
Clothes dryer not heating
I eventually changed the thermal cutoff switch and the high limit thermostat as suggested in one of your replies to another consumer and now the dryer is working fine. Thanks.
Nov 13, 2008 | Zanussi TC7114W Electric Dryer
Nov 07, 2008 | Kenmore 63942 Dryer
Apr 16, 2008 | Kenmore 43142 Front Load Washer
Kenmore 43142 Front Load Washer Logo
166 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
