My 7 year old Phillips 42" plasma has started to go blank - with the red light on the side blinking. Only solution is to manually turn off the set, turn it back on - red light constant - then turn it on (green light). This works for a minute or two, then the same thing all over again. The frustrating part is that it happens intermitantly - usually at a very inappropriate time! Sometimes it won't happen for days - other times it happens every two hours.
  • gravestock Oct 14, 2008
    No external power supply. Happens when it's cold or hot - doesn't seem to matter.
  • 19,396 Answers
Often this happens because the power board is faulty, let me know the model and tell me if it has an extermnal power supply
Posted on Oct 14, 2008
  • Ginko
    Ginko Oct 14, 2008
    Probably you need to replace the power board, also the main board can be cause for the problem.
    When it gets hot after a while some defective component fail, and TV goes blank.
    The TV should be tested by a technician, and the defective part replaced.
    If you decide to call a technician you can use the number listed on the service manual.
  • Ginko
    Ginko Oct 15, 2008
    Here you find all the parts for your TV.:42FD993517
    Power supply board is $239 POWER SUPPLY, main board is over $1000
    If it is the power board , or the main board, this can also be repaired replacing bad components, for this reason is better to take the tv to a workshop or to call a technician.
    Also contact Philips calling the number in the manual, and ask if they can sell you a warranty extension.Otherwise see here :Get a Warranty Extension
    And get the repair covered with the extended warranty.
replace sc board and do firmware update or problem will come back!
Oct 24, 2009 | Panasonic TH-42PZ77U TV
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
Phillips 42 In Plasma Blinking Red Light Only
blinking link means there is a problem with the software -- usually this is caused when a fuse goes bad or the power supply board needs to be replaced due to a problem --- most repair places replace the whole board - nobody fixed one broken part
Feb 28, 2009 | Philips 50PFP5332D 50 in. Plasma...
42'plasma phillips tv
I had the same problem and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check
for more detail.
Jan 06, 2009 | Philips 42FD9932 42 in. Plasma Television
Phillips Plasma - Model #42PF7320A/37 - 3 flashing red lights
it sounds like you could have a signal board problem they are pretty expensive but there is a web site that sells refurbed parts
Nov 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Phillips 42" plasma42pf5321d-35
Replace the small signal board 313926727671.
Oct 04, 2008 | Philips 42PF9630A 42 in. Plasma Television
Phillips Plasma 42PF3320
I have phillips 42" plasma tv it has 7 red light flashes at start up and locks out
Jun 15, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Televison & Video Logo
Top Televison & Video Experts
