Question about Linksys Wireless-G Broadband Router
Router wont recognize a valid (running)internet connection
Although i can access the internet through explorer on my desktop w/o any problems. when i try to install the wireless router (and have tried EVERYTHING TWICE) i still cant get the router to aknowledge the internet connection---im running windows vista and have comcast cable internet
  • jason May 11, 2010
    unplug the power to the linksys(reset) , check the pin connections in the plug on the router to make sure there not bent , pushed down , or not in alignment otherwise you could have a bad connection in the router , what do the lights indicate on the router
    Problem Solver:
  • 35 Answers
My Toshiba r15-s822 isn't connecting to a wireless network and the router I already installed the router to my pc even connected an internet cable to it but Internet Explorer wont open it keeps...
Try connecting to the Internet through the ethernet port (via a cable). If Internet Explorer loads the target page then you have a configuration problem with WI-Fi access : The wireless security settings are not allowing the computer to access the Internet.
If Internet Explorer does not connect with the cable then the problem resides with Internet Explorer. Try to reset the defaults. To confirm that download FireFox and use it. Besides you need two browsers just in case one acts up.
Jul 02, 2011 | Toshiba Satellite R15-S822 Tablet PC
I already install the d-link but the problem is i cannot connet to the internet
Try to connect directly the computer to your router. If you have internet connection, try to go to the routers page and from there you can setup your wireless connection. To access the the router page, go to start, run, cmd. Type ipconfig. you will get the default gateway. Then type the default gateway on the address bar when you open Internet explorer. These will open the router page. Then enter your username and password. From there you can already configure your wireless connection
Apr 06, 2011 | Computers & Internet
My lynksis router can detect the signal of the broadband connection but it cannot access the internet. when u try to browse any website it always says 'Error 105 (net::ERR_NAME_NOT_RESOLVED): The server...
This sounds like the router does not have DNS settings.
Check the web configuration to make sure that the DNS settings are valid. If there are DNS servers in there, try changing them to 8.8.8.8 and 8.8.4.4 and see if you still get the same problem.
Hope this helps!
Oct 18, 2010 | Linksys Wireless-G WRT54G Router
Not seeing the internet. We have a sattelite internet system and the modem works great. I am wired into it now andhave internet no problem. But when I run the "EASY" installation of the wireless router, it...
If you are having difficulties accessing the Internet, you need to do MAC Cloning.
Disconnect your computer from the modem first and plug it to port 1 on the back of the router. Access the router's admin page by typing http://192.168.1.1 on your Internet Explorer. When you get to the router's setup page, look for the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the modem was directly connected the last time. This will place the MAC address of your computer into the router. Save settings then turn off the router.
Now connect your modem to the WAN/Internet port of the router. You connection should be: PC to port 1, Modem to WAN/Internet port. Reboot the router and reboot your cable modem as well.
You should be able to go online after that.
Aug 05, 2009 | Computers & Internet
My apartment receives its internet connection via ethernet from an external router. I had been using the Belkin F5D7231-4 as a wireless router (not configured as an access point) but recently it dropped...
You don't want to set a static IP address in your wireless router. You'll be connected to the network alright, but the IP address won't be recognized by the primary router. Thus, you'll see you're connected with only local access.
First and foremost, ensure that your Internet connection is valid. Plug the ethernet cable from the wall directly into your computer and test the connection. If you can't get it to work, then the problem is not on your end. Contact the agency in charge of the external router (e.g. apartment maintenance).
If your connection is fine hard wired, you may have bad data or a faulty configuration in your wireless router. I suggest doing a complete hard reset (there should be some instructions with your router on how to do it--some have a small flush mounted button that you have to press for a few seconds). Set up your wireless router as if for the first time. This should take care of your problems.
May 23, 2009 | Computers & Internet
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
My destop can't get online
if you previously used the desktop to access the net using a modem, open up internet explorer, then click tools,then connection tab, then tick never dial a connection.
close IE then open it up again and it should connect
Aug 18, 2008 | NetGear RangeMax WPN824 Wireless Router...
Cannot connect to the internet
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router on this pc or if you briefly used it.
Aug 18, 2008 | Dell Wireless 2350 Router
I cant get onto internet explorer it says dns error can you help?
Check out your internet connection and its settings, whether it is dial up or broadband oriented.
then you have to know about your ip address of dns server in the network setting places.
you just ping the ip address of dns server following as...
go to start, then run and type "cmd", and it shows the command prompt. type as following format.
ping 10.10.10.5 and press enter key.. this is the sample ip address only. if it gets reply, your dns server is ok. you can use internet. suppose, it wont comes, ask your service provider or support for another or different ip address of dns to check it out.
Jul 21, 2008 | Computers & Internet
I cannot get my new computer to recognize the linksys router I have Model No:WRT54G
do a search for linksys easylink advisor. it will guide you through setting up your second computer.
Feb 17, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
102 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
