Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water leaking from water pump cap
Water is leaking from the screw cap on the reservoir for the water pump on my kenmore he3 front load washer. not sure if this cap can be replaced. is there a part number specific to the cap?
  • 5,911 Answers
Not that I know of. All sources I have found show this as one complete unit which includes the pump motor, reservoir housing and clean out trap (cover). The cost varies between $70 and $120. What I would recommend, before you assume you need to replace anything, is to remove the cover and clean the threads on the housing and cap really well and dry them. Then, apply a film of petrolium jelly on the threads and screw the cap back in place nice and snug. If there is an o-ring, make sure it is not torn or kinked, and is seated in the its groove properly. NOTE: O-rings can be found at any automotive or hardware store is you need a replacement. If there are no visible cracks on the reservoir cap, this should work. I would recommend that you remove the drain hose from the standpipe at the wall and use a wet/dry shop vac to drain all the residual water in the tub and drain lines BEFORE removing the cap. This will minimize any clean up you may have. I hope this helps you. Let me know what you find.
Posted on Oct 15, 2008
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
Feb 27, 2011 | Kenmore Washing Machines
Kenmore Elite HE3 front loading washer, model 110.45872400 - completely drains and runs correctly but sometimes an hour later there will be water in the tub
Your water inlet valve is leaking it needs to be replaced.You need to remove the top to access it.There are screws along the back edge holding it on.
Jul 24, 2010 | Kenmore Elite 45986 Front Load Washer
What is the most common reason for my washer to leak water
leaks are usualy from the drain or fill pipes, or door seal(front loaders), and lastly, the pump.
I recommend starting at the hoses, then check seal, then pump
Nov 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
What does F2 code mean with the Kenmore Elite HE3?
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
*&^% screws!!!
F2 = Long Drain. Most common cause is something (or lots of things) stuck in the drain pump. There are screws at the bottom of the front panel that can be removed to check it out. If the screws look like stars they are Torx head screws, get driver from most home centers.
Go here for Kenmore HE3 washer parts:
http://www.repairclinic.com/Kenmore-Washing-Machine-Parts
www.RepairClinic.com
Feb 03, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 will not hold water leaks into the pedestal
run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
66 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
