Question about Kyocera Switchback KX21 Cellular Phone
Searching my phone was fully functional one minute the next it began displaying ''searching'' on the scree as if it had lost signal. this continued for a while so i powered the phone off and back on and it was still searching. i removed the battery and same result. i then called my carrier support line and they walked me through some steps which did nothing to help me. if anyone has any suggestions or answers i would greatly appriciate it. thanks for your time.
Actuall just solved it just turned the phone off but thanks anyways
Posted on Oct 27, 2008
Same problem but i cant access network settings its a newwer flip phone
  • 22 Answers
Try setting the network lookup to manual instead of automatic. That way it would only look for a signal when you want it to.
Posted on Oct 15, 2008
Cheryl j11 radio beeps and says t p lost
Chery J11 radio beeps and says TP Lost
The Short Answer
This can be pretty annoying as the beep occurs every few minutes. The cause is that the advanced features of the radio are searching for broadcast traffic information, and can't find it.
Generally, only some of the radio stations in major cities carry traffic information, so this feature may not be very useful to you anyway.
To disable the beep, press the TA/AF button on the radio for more than 2 seconds, and you should see AF OFF appear on the display, meaning that the Traffic Announcement Alternate Frequencies feature is no longer searching for (and not finding) traffic information.
Unfortunately, the Chery radio manual doesn't fully explain this.
More...
Traffic Information (TA) Control
Some stations broadcast on the FM waveband have a TP code to signify that they carry traffic programme (TP) information. This is part of the RDS (Radio Data System) used on FM.
Activating traffic announcements
Before you can receive traffic announcements (TA), you must press the TA button. A TA display will appear to show the feature is switched on.
Note: On some units a short press to reach the TA feature.
If you are already tuned to a station that broadcasts traffic information, TA or TP will also be displayed. Otherwise the unit will search for a traffic programme and display TA SRCH or TP SEEK while doing so. If it cannot locate such a station, Not Found or NO TA will be displayed.
Info from
https://www.scribd.com/doc/60900285/audio-guide-1-cg3508en-01-2006
TP lost
If the TP signal of tuned station is lost after 30 seconds, an automatic TP seek for the next TP station will be performed. If no TP station is found, the unit will remain at the current station and display "TP LOST" for 2 seconds, and emit a beep.
TP seek will be performed periodically few minutes until a TP station is found.
Info from http://www.ryedalegarages.co.uk/data/uploads/docs/kia_venga_owners_manual.pdf
Posted to
http://www.cars-directory.net/problem-solving/chery/chery/11154.html
audio guide 1 cg3508en 01 2006
2011 Chery Chery Solving Car Problems chery
Sep 18, 2013 | Car Audio & Video
Tip
How to set your Global Atomic G-Force digital watch
This watch says "Strong Ideas" on the back instead of a 4 digit number.
Press LIGHT briefly and your LCD will be back lit for 5 seconds.
Press MODE to cycle through normal, alarm, dual time, and stopwatch display mode.
Hold MODE for 3 seconds to enable the radio to receive time signals. Once RC is activated, the watch will search for time signal automatically every day.
Hold LIGHT for 8 seconds to disable the RC function.
Press MODE, SET, and ADJUST simultaneously to reset the watch.
Press ADJUST while in normal mode to toggle year/time display.
Press SET while in year display to alternate Month-Day or Day-Month.
Hold SET for 2 seconds while in normal mode to cycle through world atomic radios (US/GB/DE/JP) push ADJUST to change, and SET to continue. Next the language will flash (GB/FR/DE/ES/IT). Next is DST on/off. Next, in order are hour, minute, second, year, month, day, and 12/24 Hr format.
(US only) Press SET to display timezone. The default is PA, use the ADJUST button to cycle through MO, CE, or EA as desired.
Press SET while in alarm mode to toggle alarm on/off.
Hold SET for 2 seconds while in alarm mode to change the hour and minute with the ADJUST button.
Press SET for 2 seconds while in dual time mode and ADJUST +/- 23 hours from normal time.
Press MODE to exit most settings.
Press ADJUST in stopwatch mode to start/stop the timer accumulatively.
Press SET to reset stopwatch to zero, or split measurements if timer is running.
Change the battery with a new CR2025 to prevent damage that low or dead batteries can cause by leaking.
Do not use solvents to clean the watch, use only a dry or water moistened cloth.
Do not use buttons when the watch is wet. Water may penetrate the watch and cause damage to it.
on Dec 31, 2011 | Watches
GXT950 display blinking
It has lost its base programming. Take it to a 2-way shop or contact Midland at their web-site.
Jul 23, 2013 | Midland Two Way Radio
Phone says searching
Bring the handset that says searching into the same room as the base and see if the handset stops searching. Next unplug the handset batteries (yes from all handsets) and the base power cord (from both the base and the wall outlet). Wait a few minutes and then reconnect the batteries and base power cord. Next try to de-register and then re-register the handsets. (If you add a comment with the phone model, I'll help you with this step. Uniden has the manuals for their phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl .)
If this doesn't help, next try a new battery (and make sure that the battery is fully charged) for the phone. (If the phone is under warranty, contact Uniden. Note: batteries lose their ability to hold a charge over time. This includes the time on the shelf in the package.)
If a new battery doesn't help, then there is something wrong with the handset. Decide if it is worth having the unit fixed if the phone is out of warranty.
I hope this helps.
(I'm assuming that both handsets are cordless. If you have a corded/cordless model, then check that the base has power before you go farther with the above diagnostics. The power brick should be warm. We had a cordless phone on a power strip (UPS) that got turned off. The handset was searching for a signal that wasn't being sent. If you have power to the base, try sending the Find Handset message. The problem could be either the base or the handset not sending and receiving the signals between them.)
Dec 11, 2011 | Uniden DECT 6.0 Cordless Phone
The battery life of my ku990 is abnormal
The two main causes of battery life loss that no one thinks of are:
backlight settings (if you don't really need the backlight to stay on for 60 seconds after the last button press, lower it. this is a huge waste of battery life and it is easily changed in the settings menu of nearly every phone i have seen)
poor signal areas (when you have low signal, you phone wastes its battery life searching for acquirable signal. if it is unable to locate the signal, it will continue to search. this search uses up your battery life quite rapidly)
Jan 02, 2010 | LG KU990 Viewty
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Samsung e250 limited service
you have a prob in signal reception. it is hardware related. if you can open your phone, try checking its antena connection probably it lost its contact to the board. or worst it has a problem on its hardware parts.
if you can't open your phone have it repaired to technicians coz it is mostly hardware related...
Oct 01, 2007 | Samsung SGH-D900 Cellular Phone
Limited service continuously displayed
GO TO NETWORK SETTING N SET YOUR BANDWIDTH
Continuous Limited Service display
i have the same phone and which has the same problem i rang customer service to see if they could help they told me to try my simcard in a different phone and the sim works no problemwithsim they told me it could be the phone that is broke only had the phone 3 month
Signal indicator flashes constantly
The following worked when I had what appears to be the same problem. Solution :- Remove batteries, remove power connection, wait 30 minutes, re-connect power and replace batteries then press button on base until it beeps. Both handsets started continuous beeping which eventually stopped and everything was returned to normal. Admittdly this sounds almost identical to the process used by 'versailles' above, but at least it confirms that the technical info given by the BT Helpline does work
Nov 28, 2006 | British Telecom Freestyle 2200 Trio...
Kyocera Switchback KX21 Cellular Phone Logo
51 people viewed this question
Top Kyocera Cell Phones Experts
Computer Repairing
Computer Repairing
DROPNDEAL
DROPNDEAL
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
