Question about Belkin (F5D8231-4) Wireless Router (F5D82314)
N1 wireless Router
I had one computer on this router for about 6 months. I ran a wire to my shop about 200 ft. When I hook up the wire to #2 computer, and #2 slot in router, I have a message that the cable is not connected. I have checked the wires for continuity, and there is not a problem. Is there some setting I have to change?
  • 905 Answers
Check to make sure the each pin connnection in the plug on both the router and the computer are not bent , pushed down , or just not in alignment , also you can try unplugging the router then plug it back in
Posted on Oct 14, 2008
My internet is greatly reduced with Belkin N1 vision wireless (before the hook-up it was 15mbps now only 5mbps), I have tested by hooking directly from the modem to the computer and got 15mbps. Before N1,...
When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
Mar 08, 2011 | Belkin N1 Vision Wireless Router
Well my neighbor is having trouble connecting to my wireless router using a usb belkin device. It says valadating identity? how do i get him connected
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 24, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
My wireless doesnt work on my belkin n1 wireless router
Sep 24, 2010 | Belkin N1 Vision Wireless Router
Why belkin n1 wireless router security light is flashing ?
Aug 17, 2010 | Belkin N1 Wireless-N Wireless Router
Signal problem
Step 1: Connect Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer (You can use any Web browser )
Step 3:On the left, under wireless click on channel and SSID (leave the password Blank and click submit )
Step 4: Change the Wireless Channel to 6 ( If its already 6 change it to 11)
Step 5: Click apply changes
Step 6: unplug the Router
Step 7: Restart the Computer
Step 8: Plug the power Cable back to the Belkin
Step 9: Connect to your wireless network
Jul 31, 2010 | Belkin N1 Vision Wireless Router
What wires go where to hook up my linksy srx 200 router to my pc so I can view my laptop
In order for you to connect your desktop computer to this router you need to go get a CAT5 cable also called a Ethernet cable.
Jun 27, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
My Belkin n1 router disconnects from telstra every 2 hours - exac
This is a known problem with the Belkin N1 Vision Modem Router. The router keeps time by connecting to a Simple Network Time Protocol (SNTP) server every 2 hours. The solution is to go to www.belkin.com and download and install the pre-release firmware which is supposed to fix "A problem where the router could drop some connections on 2-hour intervals" among other things.
Sep 14, 2009 | Belkin N1 Vision Wireless Router
Xbox 360 router wont work with Belkin N1 Vision.
make sure u are looking for the right connection when the box opens for the connections on the left hand side u will c a small box click it u will get wireless /dialup/vpn just make sure you look for the right one also go onto ur computer into windows media into library options into sharing and search have your xbox on it will appear click on it to allow it to share with your pc i would appreciate it if you could rate this solution
Jan 02, 2009 | Belkin N1 Vision Router
N1 Vision dont connect with PS3 system, sucks on areea network cant chage anything on it
The router sound like it is not being nice. You need to ask your friend if they went in and changed things.
If the router and Accesspoint came together and your friend changed settings, then they are not talking to each other.
1. Your running wireless for gaming. Consider running straight net cable to your ps3. It is faster by far.
2. Cisco / Linksys router access points seem good and support is free 24/7 and pretty good. They make them to be a no brainer.
6 months at it, i feel your pain. If you cannot get it working consistently within 20 minutes, call support and if they cannot resolve it, return it and find another solution till it works for you.
E
Oct 13, 2008 | Belkin N1 Vision Router
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
