Question about Maytag Kitchen Ranges
Getting a F-5 code on maytag range model # CRE9400CCL. What is wrong with range? THANKS
  • 943 Answers
Hi thanks for your question. F5 says to replace the erc the electronic clock. hope this helps. if you require more assistance don't hesitate, that appliance doc.
Posted on Oct 14, 2008
I HAVE A MAYTAG ADVANCED COOKING SYSTEM MODEL NUMBER MER5770AAB WITH CODE F9 WHAT DO I DO TO REMOVE CODE ?
That code indicates a problem with the oven door Lock Assembly. If nothing can be found wrong with the door lock, then the electronic oven control would need to be replaced.
Sep 28, 2017 | Maytag Kitchen Ranges
Oven displays loc code
What is the model number?
Apr 16, 2014 | Maytag Kitchen Ranges
My maytag range has digital control for the oven seems to be locked has a code 5 ab
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab".
To disable the Sabbath mode push and hold the Clock pad for 3 seconds.
Thanks for using FixYa!
Dec 07, 2012 | Kitchen Ranges
Getting Error Code f9-5 and f9-6 on MER6770
This is a bad electronic clock assembly and it is very simple to repair. You can save a lot of money by making this repair yourself, too!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 7 PM CST and we will get the correct part, as well part removal/installation instructions to you .
We look forward to working with you. Thanks, Ella
Jan 18, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
5Ab error code for a Maytag Electric Range
You may have inadvertently set your range to "Sabbath Mode". The display actually reads "SAB". This is a feature that allows the consumer to disable certain features of the range in order to honor the sabbath. You cannot defeat it by unplugging the range or turning off the breaker either. You will either have to wait 72 hours for the mode to clear, or figure out how to turn it off.
To turn the Sabbath Mode on/off on most Maytag models you simply press and hold the "Clock" button for 5 seconds. These instructions should be in your owner's manual.
If this does not correct the problem for you, please post back with your model number (located on the back of the range or around the oven door opening) so that I may be able to assist you better. I hope this helps you.
Nov 01, 2009 | Maytag MER5775Q Electric Kitchen Range
Wolf oven e1 code
Ar you sure it isn't an F1? Taht would mean an error in the latch
Dec 17, 2008 | Wolf Range CHR-0-18-FT22 Gas Kitchen Range
Maytag double oven model # mer6770acw code f1-1 and f3-1 appears on the panel when using the ovens ofcourse when it gets warm or hot the ovens stop working.thanks for help
still i have the with oven heats up and stops working the codes coming on the panel are f 1-1 and f 1-3 range model # is maytag double oven mer6770acw
Sep 09, 2008 | Maytag Kitchen Ranges
I was setting the clock on my maytag model # PER4311ACW stove/range and then a code "5 A6" popped up on the display and now the oven won't turn on altough the stovetop still works and the display...
If your code is SaB i just did this myself....i accidentally turned on the sabbath mode. I fixed if (after 2 days of trying) by holding down the cancel button for about 5 seconds, and then the clock button for about the same.
Aug 09, 2008 | Maytag PGR5710 Performa Gas Kitchen Range
Kitchen Ranges Logo
60 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
