Question about Whirlpool LSQ9610L Top Load Washer
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
I heard this noise coming from the washing machine that I have never heard before. When I went to check it out, the water was draining from the machine but the drum was not spinning. It is making a noise like it wants to spin but nothing is happening just this weird noise. First my frig quit now my washing machine. Please help.
  • 2 more comments
  • Brakofday
    Brakofday Oct 14, 2008
    I do need help to replace. I'm having trouble getting the top control panel off. I have lossened the screws on both sides of the panel but it will not slide forward or even move so I can flip it back.
  • Brakofday
    Brakofday Oct 15, 2008
    You were right. The coupler is cracked. I will attempt to pick up the parts tomorrow. I pray that they are in stock. Thanks for the help docJohn.
  • Brakofday
    Thank you. That problem was fixed. The tub now spins, but when it stops it jerks to a stop and shakes the entire machine. What did I do?
  • Anonymous Apr 07, 2009
    lsr6132eq0 wont spin
Whirlpool top loader fills and drains but won't spin
Posted on Jan 31, 2009
  • 943 Answers
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Posted on Oct 14, 2008
  • john gagnon
    john gagnon Oct 15, 2008
    HI did you pull the screws right, if not do so. pull console up and towards you . 2 brass clips remove them disconnect wiring harness to lid switch. remove the front panel. tip washer up on a block . remove the pump 2 clips. remove the motor same 2 clips 2 screws. remove the wire harness to motor. replace the coupling if you need more help come on down. thanks
  • john gagnon
    glad i could help thanks
Whirlpool top load washer wont spin
The flexible joint under the tub may have failed
Jan 10, 2013 | Whirlpool Washing Machines
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not spin and making grinding noise
a grinding noise sound i think it come from ballbearing you can chang by qualified person
Apr 17, 2009 | Whirlpool LSN1000LW Top Load Washer
Whirlpool washer top load
The clicking is coming from a bad drive coupling:
Top loader repair tips
Feb 20, 2009 | Whirlpool Inglis IP4400 Washer
Wash machine won't start in spin cycle
Lid Switch needs to be replace. Washer wont spin without lid switch.
Dec 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool noise
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Whirlpool LSQ9610L Top Load Washer Logo
499 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
