Question about Sharp AL 1631 Copier
Copier won't print after refilling toner cartridge
I refilled the cartridge w/ toner as per directions on toner refill CD. The machine sounds like it is about to print, then recycles many times and finally the low toner light appears and machine stops. Is there anyway to let the machine know that the toner is full again?
  • rahteach Oct 16, 2008
    so I guess trying to be "cheap" and refilling the cartridge is not enough----Boo, hiss!!
    Thanks for the info.
  • 161 Answers
As far as I know, filling up with toner is not enough. There is an electronic chip that must also be replaced, so the toner cartridge tells the unit it is a new one. Check with your supplier for such chip.
Posted on Oct 16, 2008
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
Refilling toner in xerox phaser 6280
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your model printer.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 27, 2012 | Xerox Phaser 6280 Clr Laser Printer 26Ppm...
I have the 1522 printer. The toner ran out and I refilled using Chinese toner fron Deal Extreme. Black toner leaked out the right hand side of the toner cartridge messing up printing. I tried refilling...
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder. You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer. This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter. A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 25, 2011 | Office Equipment & Supplies
I want to refill a brother TN135M Magenta Laser Toner Print Cartridge how do you do it?
You don't. I own and operate a printer cartridge refilling shop and we don't offer refills for new Brother color lasers becuase there is not a quality toner available, even to us! Besides that hindrance, the way Brother cartridges work they need (should) be cleaned of used toner before refilling. These cartridges "recycle" their waste toner which can degrade print quality if not removed. It is possible to vacuum the toner, but keep in mind it can be explosive when aerosolized. If you do choose to vacuum at home be sure your vacuum has HEPA filtration BEFORE THE MOTOR. The spark from the brushes in the motor can ignite the toner.
Jun 09, 2010 | Office Equipment & Supplies
How to refil konica minolta toner
Shop for the appropriate refill kit. When purchasing a refill kit, double-check to be sure that the toner in the kit is compatible with the toner required for your model of Konica Minolta printer.
  • Step 2 Empty the old printer cartridge. Be sure to completely empty the printer cartridge that you plan to refill. A compressed air can is ideal for this purpose and can be purchased online or at most office supply stores.
  • Step 3 Remove the plug. The cartridge plug may be covered by a colored end plate, depending upon the model of your Konica Minolta printer. Simply unscrew the end plate, and then remove the plug. If using a screwdriver to remove the plug, be careful not to puncture the plug, as this will cause the toner to leak out of the cartridge and into your printer.
  • Step 4 Refill the printer cartridge. Shaking the powder in the refill toner bottle before attempting to pour it into the cartridge will cause it to pour much more easily. Do not squeeze the bottle, but allow the toner to simply pour out. Replug the cartridge, and gently shake or rock it back and forth two or three times to evenly distribute the toner powder inside the cartridge.
  • Step 5 Check for leaks. Before returning the cartridge to the printer, check the outside of the cartridge for any powder particles that may have spilled or leaked during the refill process. Wipe the particles off the cartridge, and gently shake it once more to check again for leaks. If no powder particles appear, then it should be safe to return the cartridge to the printer.
  • Step 6 Return the cartridge to the printer. Once you have refilled the printer cartridge and have checked for leaks, you may now return it to the printer. Go to your printer properties/settings and select the option to indicate that a new printer cartridge has been installed. Print a sample page to check print quality
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    May 22, 2010 | Konica Minolta PagePro 1350W Laser Printer
    Refill toner cartridge
    The toner cartridge is designed to dispose once finish... Not recommended to modified and refill...
    Feb 17, 2010 | Toshiba E-Studio167 Copier
    Where do you get refill ink for canon fax phoneL80
    The Canon Faxphone L80 takes a Canon FX3 cartridge. To get the highest quality refill I would first see if there is a Cartridge World store in your area. Cartridge World stores refill most cartridges in house with American made parts. Then try Office Depot. Office Depot is the only big box store that actually "remanufactures" toner cartridges. I would not recommend cheap refills or refill kits from the internet. Many use very low quality toner that wears on parts leading to print defects or they reuse parts that already generate print defects. DO NOT buy a "compatible" cartridge, these are not refills. They are new cartridge replicas and have no recycled components.
    Dec 16, 2009 | Canon FAXPHONE L80 Laser
    Brother Toner Refills
    Yeah you can refill your cartridge. It is really easy and consists of removing the plug on the side of the cartridge, dumping out any old toner and dumping in the new toner. Its very easy. I have purchased refill kits from both of these sites in the past and its worked great:
    www.tonerrefillstore.com
    www.lasertekservices.com
    They also have great customer service. I hope this helps!
    Nov 08, 2009 | Brother DCP-7040 Laser Printer
    Refilled toner for ml 2245 samsung printer doesn not print
    dis is quite common problem..don't panic..
    did u change / replace the cartridge with original spare or refilled it??
    this kind of problem often follows with an unbranded cartridge change and or refilling..!!
    least chance of the defective cartridge itself causing such problem..!!
    however always try to use genuine refill packs/toner..
    ..contact ur system admin/vendor....
    Oct 26, 2009 | Samsung ML 2010 Laser Printer
    Samung scx-4521f toner refil but still printing light on paper
    Donot refill the toner. Use the genuine cartridge. If you use the refilled it may cause printer damage.
    Jul 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
    Sharp AL 1631 Copier Logo
    120 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    jasbo
    jasbo
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
