Question about Epson Stylus Color 740 InkJet Printer
Epson Stylus color 740
All lights are flashing on my printer and it will not print. I have changed print cartiridges
  • 14 more comments
  • johnbarrett7 Oct 15, 2008
    Still not working. Powered off computer, removed cartridges and replaced after five minutes. No success. All lights still flashing
  • johnbarrett7 Oct 16, 2008
    Tried all that. Still no joy.
    Still no luck. Do I need a new printer?
    Tried that as well. Still no luck. Any other suggestions
  • johnbarrett7 Oct 17, 2008
    How do you uninstall and reinstall print drivers?
  • johnbarrett7 Oct 18, 2008
    Tried all that. Still no success. Got
    'communications error with printer' - first indication of problem
    Many thanks for all your help and extensive efforts to find a solution. Many thanks.
    Can you assist in sourcing a replacement upgraded printer. I do about 150 - 200 pages a week. Some color work. Many thanks.
  • johnbarrett7 Oct 19, 2008
    Can you recommend a good Epson replacement printer (+ source details,price etc - 150 to 200 pages per week,some color. Many thanks.
  • 54 Answers
First unplug the printer for 10 to15 minitues and remove the cables and cartridges and put back again then the problem is solved ,if it doesnt work its a hardware problem in case check out the adapters of the printer.
 again u go for reinstalling and installation of printer
Posted on Oct 18, 2008
  • 1,183 Answers
HI, if all the lighs are flashing on the printer, you have not removed the tape , from the contacts of the new cartridges that you have installed .
Thanks
Proton
    President:
  • 1,952 Answers
ERROR 55 - Internal Communication Problem
  1. On IIISi/4Si Printers this is due to the DC controller not receiving the proper information upon startup. Check the connectors on the DC controller and power supply. If you don't hear the motor immediately and you don't have a paper jam, change the power supply.
  • mohammed marika thambi
    mohammed marika thambi Oct 18, 2008
    to the customer service center to provide an whether the problem .
    Sergeant:
  • 306 Answers
It happens at times
i recommend you to uninstall ur printer
restart ur system
install the printer
restart ur system
n ur problem is solved !!
Else..   Turn your printer on, remove the power cable at the back of your printer while the printer is ON. PRESS AND HOLD the # key and 3 key on the keypad, plug back the power cable WITHOUT releasing those buttons, DO NOT RELEASE THE BUTTONS until you can see the WELCOME SCREEN or INPROPER SHUT DOWN PRESS OK TO CONTINUE.
Posted on Oct 17, 2008
    Sergeant:
  • 352 Answers
Hi john,
I would suggest talking to the folks here at Epson ear to ear.
United States Phone Number:
(562)276-7542
Hours: Mon.- Fri. Epson Stylus color 740 - spacer.gif 6AM-8PM (PT) Sat. spacer.gif 7AM-4PM (PT) Canada Phone Number:
(905)709-2567 Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT
anaanymous
  • 4,472 Answers
I would purchase a replacement printer as you can get a better one for 40$. Time is money and not worth wasting any more time and money on the printer. Let me know if you need any more assistance locating a replacement or any other information. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Posted on Oct 16, 2008
  • 69 Answers
Try taking out the catridges, any paper in ther printer(check for paper jam), and unplug everything including the power
wait about 30 seconds, plug the power in, but nothing else. if it works, put one thing back in at a time, until it stops working. Post back if that helps.
Also, what happened before this started happening?
Posted on Oct 15, 2008
  • 1,800 Answers
Try to uninstall and install the drivers and clean the nozzles after that and run the alignement utilty and cleaner
and restart ppc and see what u got
plz rate this post
  • Epson Master
  • 19,396 Answers
Try unplugging power cable for ten minutes and power cycling the printer, sometimes this works.
  • Epson Master
  • 1,879 Answers
Power light, Paper light, and both Ink out lights are all flashing
An unknown printer error has occurred. Turn the printer off, disconnect the interface cable and turn the printer back on. If error disappears, turn the printer off, reconnect the interface cable and turn the printer back on. If error continues then the printer is already having a hardware issue. If printer returns the normal the issue is resolved.
    Genius:
  • 1,124 Answers
Disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer.
else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
  • Pablo Csaky
    Pablo Csaky Oct 16, 2008
    Your printer has an internal issue and must be serviced
  • 6,487 Answers
Try powering down the computer for five minutes and takek all cartidges out then put it back in, then power it back ON and check if you can now print already. If still not working try uninstalling and reinstalling the printer software...
  • Mark Gil
    Mark Gil Oct 16, 2008
    You can either take this to a service center or better get a new printer already since you have alot of problem with this one....
  • Mark Gil
    Mark Gil Oct 17, 2008
    To uninstall the software for this printer from your computer , Go to Control Panel>Add/Remove programs then look for the software for your printer if its still not uninstall that should be listed there, then after uninstalling the software restart the computer, After you restar the computer run the CD for the printer and let the wizard configure everything for you.....
All lights flashing
Turn off printer and disconnect power lead, then go into your computers printer setting click see whats printing and delete
any jobs in print que. Restart your computer plug your printer power lead back in.
Jan 15, 2014 | Epson Stylus Color 740 InkJet Printer
Warning lights blink upon startup, printer freezes
If the lights flash alternately then it is probably your waste ink pads that need cleaning
If the lights flash continuously check your printer for any outstanding documents in the print queue and cancel them then try again
Mar 30, 2010 | Epson Stylus Color 740 InkJet Printer
Problem with colour printing. Orange and green
Wow, that's a really old EPSON printer. The life expectancy of a EPSON printer is just three years, after that, the printer wouldn't work because of the clogged permanent printing head. The authorized service center is unable to repair it because the spares are no longer supplied.
Throw it to a recycling center.
Nov 03, 2009 | Epson Stylus Color 740 InkJet Printer
My epson stylus 740 has lights flashing
You can try and turn if off at the mains overnight or all day.
See what it does when it turns back on
Sep 17, 2009 | Epson Stylus Color 740 InkJet Printer
Cannot print.
ITs communication problem, check the cable, and check the driver could be corrupted, reinstall the driver to make sure, and try different cable to connect.
Apr 22, 2009 | Epson Stylus Color 740 InkJet Printer
Epson won't print and all lights flash
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Mar 15, 2008 | Epson Stylus 880 InkJet Color Printer
Failure to print
inyestores tapados extraerlos y sumergirlos en alcohol isoprilico varias veces ojala dearlos de un dia para otro yo entiendo el ingles pero tengo problemas para escribir no se como me enviaran lq forma de la lectura la pueda ver en español saludos desde chile
Feb 26, 2008 | Epson Stylus Color 740 InkJet Printer
Blurred and fuzzy print quality
i think you use a compatible ink... use genuine ink for epson ok...
Jan 04, 2008 | Epson Stylus Color 740 InkJet Printer
Won't print black
just try with tet page of printer and also reinstall the driver and see. bye
Sep 26, 2007 | Epson Stylus Color 740 InkJet Printer
Epson Stylus Color 740 InkJet Printer Logo
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
