Question about Acomdata (HD080U2FE-72) 80 GB Hard Drive
I/O Error on Acomdata External Hard Drive
I have an acomdata 80G external hard drive. We use it on a daily basis for photo storage and itunes music. IT worked properly yesterday, but when I came to the computer today it gave me an I/O message. Can anyone suggest how to fix it? I've tried just unplugging the firewire and when I plug it back up it says it has to be reformatted. I dont want to lose all of my data that's on it. Please help!
  • 3,230 Answers
Go into Control Panel/System/Device Manager and look for yellow exclamation marks. Delete any you find. Reboot your computer. Connect the external hard drive and turn it on. Let Windows discover it. If it asks for the driver, put in the CD that came with the drive.
If this will not works means there is some problem in your HDD partition and you need to format them...
if you donot want to lose any data then use any recovery software to recover data from your HDD.
Good Luck!!
Thanks
Posted on Aug 24, 2009
What is the model number (and Windows 7 driver) for Acomdata external hard drive serial number AC07111300220
  • 1Connect the Acomdata external hard drive to your computer through the USB cable that came with the drive.
  • 2 Click the "Start" button on your computer screen and then click on the "Control Panel" tab.
  • Sponsored Links
  • 3 Click on the "System" button and then click on the "Automatic Updates" tab if you are running the classic view. If you are running the standard view, click on the "Performance and Maintenance" button and then click on the "System" tab.
  • Read more: http://www.ehow.com/how_6880582_troubleshoot-acomdata-external-hard-drive.html#ixzz345dOHa31
    got it by just searching and a whole buch of solution came
    May 05, 2014 | Acomdata Computers & Internet
    Trouble with my Acomdata external hard drive and my mac
    Unfortunately it seems that Acomdata is no more on businness.
    In order to get support you can try writing an email to techsupport@acomdata.com
    Feb 04, 2013 | Acomdata Computers & Internet
    I am having a problem with my external hard drive I look over and the blue light is good on the Acomdata D32OUFAPE5-72 Hard drive and then I go to explorer and it is no longer in my directory as a...
    You can remove the hard drive from the case and put it into another, new usb hard drive case. You can buy one for 20-30 dollars. I have seen this many times before. The hard drive is probably okay, but the controller inside the acomdata case is likely dead. Don't worry, just get a new usb hd case.
    Hope this helps!
    Regards,
    Joe
    Jan 04, 2011 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
    My external hard drive fell off my desk and since it has been beeping and not operating correctly
    You broke it. Does the Acomdata warranty cover self-inflicted damage?
    Did you buy it with a credit-card that adds "all-perils" insurance?
    All you can do is to disassemble the enclosure, remove the disk-drive,
    buy a similar, compatible, disk-drive, install it into the enclosure,
    and thus "revive" your external storage device.
    Nov 02, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
    Acomdata HD120U2FE-72 120 GB external Hard Drive
    OK, 2 things to check. First and foremost, when you plug it into the PC does it make that nifty noise to let you know it sees a new piece of hardware?
    Second, if it does, you probably need to initialize the disk. Hit the windows button, right click on computer, and select manage. Under the storage category highlight Disk management. If you see the drive there, you can right click and select initialize, or format. From there the system should see the drive.
    Feb 06, 2010 | Acomdata HD120U2FE-72 120 GB Hard Drive
    Acomdata 250 external (SATA) hard drive not showing up on desktop
    be safe
    go on line to acomdata web site and down load the driver from there
    Oct 11, 2017 | Acomdata (HD250SE5-72-PCI) (HD250SE572PCI)...
    Problems with Hard Drive
    Appreciate the direct "Ask Me".
    T your concern:
    • initially, pls verify that it is indeed an external storage problem rather than a laptop USB issue by trying other USB devices and determine if they are recognized and working;
    • disassemble the enclosure of the Acomdata external hard drive and remove the actual hard drive;
    • you would need the use of a 2nd PC, a desktop that could accommodate the HD from the Acomdata (IDE or SATA);
    • install the HD from the Acomdata as a Secondary Master or Slave internally to the 2nd PC;
    • boot the 2nd PC and determine if the HD from the Acomdata will be recognized as a local drive;
    • chances are that the partition of the HD from the Acomdata was messed up. This would explain the blinking blue light;
    • download and install a file recovery program. An example is GetDataBack (unfortunately not a freeware but DEMO is available) and do a recovery. It would take some time based on the size of the HD from the Acomdata;
    • temporarily save the recovered data in the 2nd PC. You can burn this likewise into a DVD backup should the 2nd PC be capable of that;
    • after recovery, re-partition and format the HD from the Acomdata while still attached to the 2nd PC;
    • should the re-partition and format be successful, you can transfer back the temporarily saved recovered files;
    • a nice, simple, fast and safe partitioning/formatting software is Partition Magic (unfortunately not a freeware but FREE TRIAL is available).
    • should the re-partition and format be not successful, you can replace only the HD and/or claim warranty.
    Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
    Good luck and kind regards. Thank you for using FixYa.
    Sep 01, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Bootable drive
    check in your bios for setting boot from external device
    May 14, 2008 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
    Forgot Acomdata External Hard Drive Password
    Did you every get this resolved? I have same probelm.
    Apr 08, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
    Acomdata (HD080U2FE-72) 80 GB Hard Drive Logo
    271 people viewed this question
    Top Acomdata Computers & Internet Experts
    Jerry Umali
    Joe Goldman
    Joe Goldman
    Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
