How to change spark plugs 1998 Expedition
Hi Glloyd806
the spark plug gap is .054
This is at best difficult and if not done right can destroy your heads
( about $2700.00). My advice is to have the dealership take the risk.
However, If you decide to change the spark plugs yourself you'll need
to know a few critical things first.
The 5.4L has aluminium heads, there is a design flaw in that
the thread depth is to shallow, only 4 or 5 threads. because of this it
is EXTREMELY IMPORTANT to apply anti-sieze on the threads of each spark
plug and torque the plugs to NO MORE THAN 14 LBS. Also, if the plugs
have been improperly changed before, it is to late, and you will rip
the threads out when removing the old plugs.
Still wanting to do it yourself? OK here is how it is done;
Each spark plug has it's own coil, you will need a 8mm socket to
remove the retaining bolt. Then disconect the coil wires on the coil.
pull out the coil assembly (coil and boot). they may be stuck a little
so you may need to wiggle it out. Now you are ready to remove the spark
plug. You will need a THIN WALLED 5/8in spark plug socket, at least one
extension, and on the #3,4,7, and 8 spark plugs you'll need a universal
joint. the holes that the spark plugs are in are machined very thght
and I found that I needed to try several different sockets before I
found one that would fit inside the hole. Remove the old plug. apply
anti-sieze on the threads of the new plug and install. DON'T CROSS
THREAD, THERE IS ON SECOND CHANCE! TIP.. replace the old rubber boot
with a new one and apply a liberal amount of spark plug moisture
protectant gel inside the boot, spark plug end, this will save you from
spark plug mis-fire due to moisture in the future. Place the new boot
back on the coil and place the coil/boot back into the spark plug hole,
it may need some wiggeling. Replace the coil retaining bolt
(anti-sieze), reconnect the coil wires. Now do this 7 more times.
In all honesty, take it to a Mechanic, because this is a real pain in the....
Best of luck, and I'm not responsible for any damages you do :(
Lazaruselite
This is a USA based site, we have info for USA and most canadian cars. No Fiesta sold in USA.
