Question about GE 30 in. JP385 Electric Cooktop
All 4 burners stopped working - circuit breaker ok
GE JP385 electric cooktop problem. Worked ok at breakfast then went to turn on to cook dinner and none of the four burners worked. Checked GFIs and circuit breaker in the box (even turned off/on again) and all looked ok. Removed all four heating coils and put back then Removed the left coil surface unit and replace with the grill module and nothing happens. Can't believe the four burners are wired in series but ..... Any help would be greatly appreciated. -Dan
  • GE Master
  • 1,830 Answers
How old is this cook top stove? Does it require replacement?
Posted on Jun 11, 2017
fridgetech
  • 473 Answers
SOURCE: ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Posted on Oct 26, 2007
SOURCE: gas cooktop vent code
planning to install a 30" stovetop natural gas.need to know if i need a vent to the outside, it has 4 burners
Posted on Feb 20, 2008
  • 161 Answers
SOURCE: GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Posted on Jul 15, 2008
Eddie Rentas
  • 59 Answers
SOURCE: Cleaning glass cooktop surface
Yuo can try with sand paper grid #600, but you have to use it wet, Just pour some water on the top and get the sand paper wet and concentrate on the stains only, and they should come out without scratching the glass.
Eddie Rentas
Tupper Lake NY
Posted on Jul 23, 2008
  • 113 Answers
SOURCE: Popping noise and red light
it could be a switch, element or a short somewhere else
Posted on Apr 29, 2009
GE Profile mod. PP975bM3BB all lights work Burner will not heat
You have lost half of the circuit in the breaker, the lights work on one side of it but the burners need both sides of a 220 volt circuit. I would have the breaker tested first, and if it is good, look for a fuse, relay, breaker in the back of the stove. Hope this helps.
Mar 06, 2012 | GE Profile 36" Electric Induction Cooktop...
I have a 4 burner Jenn-Air JED8430ADB electric radiant heat stove that has recently stopped working. It has been installed for many years (came with the house) and worked fine until now. When I turn one...
The cook top is connected to 220 volts. In the house wiring there are two legs each 115 volts. Usually they connect with a red wire, black wire and the third a neutral. It is likely that at the connection to the unit or at the electrical box a connection has failed or the 220 volt circuit breaker has failed on one leg. A qualified electrician needs to do the repair!
project1-nbbnxwvnfadegsi2zsme4jri-2-2.jpg Hope this helps?
May 04, 2017 | Jenn-Air JED8430 Electric Cooktop
Breaker in panel tripped and won't turn back on
You may have a short circuit to ground fault in the electric cook top. Divide and conquer. Unplug the cook top and try to reset the breaker. If the breaker resets, then you have a problem with the electric cook top. If it doesn’t, then the problem is at the electrical panel side. Either problem will require a qualified technician’s assistance. I hope this helps. Good luck.
Jul 16, 2010 | GE 30 in. Profile JP938 Electric Cooktop
Cooktop keeps blowing fuses. when we hit the
you will have to remove top and find short . it sounds like a burner of melted wiring. .. also ck the swithces for dark connections as the could be the cause. mm
Jun 30, 2010 | Maytag MEC5430 Electric Cooktop
Stove is tripping circuit breaker Two burners stopped working properly (only get slightly warm). Switched the coils to the other side and the other side is still working. Looked underneath and saw that...
if it is an old stove i would say have it serviced/checked over. if it is a newer stove i am guessing the circuit breaker predates it and is rated for the old stove therefore you will need to have a larger circuit breaker installed (by a licenced electrician)
Mar 04, 2009 | Jenn-Air Expressions AC110 Electric...
GE profile performance electric cook top is not producing enough heat in the front burners.
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
Burners on JP326 electric not heating
Sounds like breaker tripped so no 220 to unit. Reset breaker. The burner switch you first turned on probably blew out and needs replacing, so don't turn it on again. If all else works ok, then that is it. Unless you are handy you may want to call the repair man.
Nov 30, 2008 | GE 30 in. JP326 Electric Cooktop
Cook top "popping" noise
make sure the heater elements are properly nested into their respective electrical sockets. if they get loose, then the electrical contact can be intermittent and arc/spark a bit..
Sep 10, 2008 | Kenmore 30 in. 44022 / 44029 Electric...
GE 30 in. JP385 Electric Cooktop Logo
227 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
