Question about Stanton C.313 CD Player
After putting a cd in, it will load up and sometimes even play but then goes right back to displaying "read" on it like it cant read the CD.
    Genius:
  • 1,175 Answers
Hi...
Find someone whos not afraid of technical stuff to clean the laser lens and rails that the laser pick-up runs on.
Also get the drawer belt checked for loosey-goosey
Posted on Mar 25, 2009
Static sound from one channel after playing for a while--time it starts varies.
You don't say what a 1055 is and it is hard to know what you are asking with a lack of ID on the equipment at fault. Sounds like a source selection problem maybe a switch or if electronics a CD4066 IC.
Mar 25, 2013 | Audio Players & Recorders
The cd player goes into a "skipping" "playing really fast" mode occasionally. Esp. 3rd track, 1st cd. Always has.
It's having trouble reading the CDs. The thing that reads it could be dirty. But try a different cd. The CD player is getting old and if there is even a small scratch it will be hard to read it. A new CD player would be the way to go
Mar 14, 2013 | Audio Players & Recorders
Technics SL-MC60 error message: "Take out"
Hello
If a disc has been put in the slot of the disc in play, Remove the disc, whose number is displayed, and press stop button.
Because of light or noise, the changer has detected a disc in the lot of the disc being played, even though it is empty. Check whether there is a disc in the displayed slot. With front panel closed, hold down "STOP " button for atl least four seconds or more.
Feb 03, 2012 | Audio Players & Recorders
When I load a cd in my Stanton C324 it reads "No
Hello
Clean your CDs before and after playing them. Although the compact disc has a much longer lifespan than does something like a cassette tape, it can be more fragile. Scratches, dust or other damage to the data side of the CD will cause many CD players to fail to read the CD or cause the CD to skip.
Examine the type and format of the compact disc if your CD player fails to read it. Verify that your CD player can read the type of CD and the files contained on it. Just because you've burned a collection of songs to a CD, for example, doesn't mean that your CD player will be able to recognize that information. You must burn CDs in a specially formatted "Audio CD" mode to play them on a CD player, or your CD player must be able to recognize the MP3 file format. Some CD players have limitations on the type of CD they can read. Verify that your CD player can read CD-R, CD+R, CD-RW or CD+RW compact discs.
Update your CD player's driver, if your CD player is a drive connected to your computer. Click "Start" and select "Control Panel." Click on "Hardware and Sound" and select "Device Manager" under "Devices and Printers." Right-click the icon for your CD drive and select "Update driver software." This may solve any issues the drive was having with playing CDs.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Stanton C324 Mp3 Cd Player With Effects...
I Have a Philips CDR820. The problem I have is that the system is "freezing up" and wont play. The troubleshooting manual says to unlug the player for a short time and plug back in. I do this...
What does the display read when this happens, I have experience with these, does it say disc recover? also when the laser reader gets old, it may be done, unless you can maybe find someone with replacement. Old or scratched cds won't read well, or skip also.
Jan 01, 2011 | Philips CDR820 4-Disc CD Recorder
Nad 502 CD will not recognise and play CD every time
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens, or misaligned loading mechanism. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more
Sep 14, 2009 | Teac CD-P1250 CD Player
CD tray wont stay closed
Try using a CD cleaner. Generally this sort of problem occurs due to dust accumulating on the lens. The CD cleaner comes along with a solution.just spray on the CD and allow it to play in the CD drive. Sometimes the problem might even be due to a virus. Check whether your anti-virus is up to date.
Nov 30, 2008 | Integra CDC-3.1 CD Player
Numark cdn95 left player skip even with new cds
CDN95 uses the same CD transport as a CDX, aka....junk. Its mostly likely defective, replace left CD drive.
Oct 13, 2008 | Numark CDN95 2-Disc CD Player
Won't stay closed
even if the laser lense cant process the data being read it should not eject and just display disc error or no disc. That's how it normally does. anyway if is is different from yours, try cleaning the laser lense with cotton bud, dampen a bit with rubbing alcohol, then the other end to dry it. rub it in circular motion please and not too hard or excesiove force on it.
lubricate the spindle motor shaft if you can reach, not too much oil, the very thin type household use only. likewise the traverse mech. the mech is not the source of your problem but since you are lubricating the spindle motor then you might as well lubricate the rest of moving parts. try not to put oil in you platine table and other rotating parts like the rubber belts or you'll find another problem later.
Reden
Dec 12, 2007 | Yamaha CDC-502 5-Disc CD Changer
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
Stanton C.313 CD Player Logo
144 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
