Question about Iwill ZMAX-DP (MCZMAXDP) Barebone
I need spare parts for my zdmax dp (motherboard)
Motherbaord faulty need a new one
help whern can i get a replacement?
I have 2 Zmaxs Dps,1is nearly new and has been tested,(spec on request) Colour RED. The other was working but i am selling it as spares because i intended to use it for parts.( BLACK). I think the Black one is also O.K. except sometimes you have to fiddel with the Power lead to get it to run.
Posted on Jan 01, 2009
  • 145 Answers
Go to the service web page for that pc
Posted on Dec 16, 2008
How do i fix a tv sanyo DP 42849 IS NOT TURNING ON
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Electro help
Nov 13, 2014 | Sanyo Televison & Video
Error 174
Error 174 is hard disk drive failure, you'll need a new hard drive. But since that is a 2002 era system you might consider a new notebook too.
Jul 10, 2011 | IBM ThinkPad 600X Notebook
I have tried 3 monitors on my pc and all of them give the same over-bright output but when connected to another pc the monitor is fine. is my on board graphics faulty
It could be one of two things, either the video portion of your motherbaord is faulty, or you have a graphics driver issue. I would look and try to download new drivers for your mobo, that might just fix your problem.
Jan 18, 2011 | Gigabyte GA-M51GM-S2G Motherboard
My dg31pr motherbaord do not show display and the numlock is off
There is problem with your motherboard, your motherboard's winbond chip is damaged so replace it from vendor.
Regards
Ashly
Jan 29, 2010 | Intel DG31PR Motherboard
How much would It cost me to get the motherload on my laptop replaced.
I6000 motherboards run about $150 on Ebay and labor is usually about $100 to $150 to have it installed.
Sep 25, 2009 | Dell Inspiron 6000 Notebook
No light on Motherboard Asus P3B-F
if yo have no light on the motherbaord this means that the PSU (Power Supply Unit) is either faulty (so no delivering 5v to the motherbaord) or is not plugged in properly in order
1. does something else that works somewhere else work in the plug you are using for your PC (yes goto 2 No you need an electrician to look at you mains sockets)
2. Does PSU have an independent Power Switch is it ON
3. Unplug and plug back in you power leads. (does it work OK if not goto 4)
4. Does the power light come on your VDU if yes swap the power leads from VDU to PC (does PC power up and screen dead if yes replase fuse in Plug - like for like - if no goto 5)
5. Problem is most likely with PSU replace unit for another one the same - be sure to get the same number of ATX connectors you can get a 20 and a 24 pin variant
Jun 28, 2009 | ASUS P3B-F Motherboard for Slot 1 CPU
Configuration for my motherbaord
Look on the motherboard for all numbers,names and info. This will help ID the motherboard. Then enter info at dell support site search engine that should give you the info you need.
Jan 15, 2009 | Dell Computers & Internet
Replacing Asus CUV4x Motherboard with Asus p5vd2-vm-se motherboard? I have my old computer that i want to replace with new set of motherboard. My old computer has the following specification: Asus CUV4x...
Hi eibral2345, sorry but there is no chance the motherboard, Asus P5VD2-VM-SE will run the Samsung memory. It’s the old style 3.3V PC133/100 SDRAM. The new Asus motherboard,
P5VD2-VM-SE uses Single-Channel DDR2 - 667MNz or 533MHz memory. Here is a link to the specs of the Asus CUV4X: http://www.pcstats.com/articleview.cfm?articleid=314&page=3
Here are the specs for the Asus P5VD2-VM-SE MB: http://www.asus.com/products.aspx?modelmenu=2&model=1787&l1=3&l2=11&l3=369&l4=0
Will the new Asus board fit in your case? It should!
The larger measurement is the height of the board.
The Height + Width of the new board is smaller than the older board.
Have more questions?
Good luck eibral2345!
Mike
Sep 26, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Motherboard m2n mx bio
You need to update your BIOS by a latest version from the asus website. You just check it from there.
Jun 26, 2008 | ASUS M2N-MX Motherboard
Computers & Internet Logo
192 people viewed this question
Top Iwill Computers & Internet Experts
Alun Cox
Josh Whitehead
Josh Whitehead
David
David
Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
