SOURCE: where is coolant temp sensor located on 2003 gmc
heres a diagram to show you where the coolant temp sensor is located, its behind the alternator on the left side (driverside),the sensor just unplug the connector and then unscrew it and out it comes.
SOURCE: check engine light on - 2003 gmc envoy XL
That code represents a lower than expected reading for temperature (coolant). First thing to do is check your coolant level, as if it is low, then the sensor can not read correctly. Second, you may have a thermostat that is stuck open, allowing the coolant to cool off too much. The sensor should be mounted on top of the engine, near the thermostat housing.
SOURCE: where is the 4x4 encoder motor sensor located on my 03 sierra
the encoder motor sensor is inside the encoder motor. the encoder is located at the transfer case. Remove the encoder and by part number 88962315 this is the sensor. you will have to retime the motor after
hope this helps
SOURCE: where are the oxygen sensors located?
There will be one located before, and one located after the catalytic converter for each exhaust that you have
SOURCE: Location of coolant temperature sensor on 2003 GMC
on the left front of the block by the alt. 4.2 L engine
