Question about E-Machines eMachines Desktop PC
What kind of ram do i need for my desktop
I have a e michine desktop and i had a problem with my flash and i was told i needed to install ram how would i do that and what kind do i need any help would be nice thank you
  • froggy567 Dec 17, 2008
    I an emachine (W3621) it is running really slow and has rebooted itself while I was on the internet, I was told I needed to add more RAM, but I dont know what kind to buy. Thanks
  • angelianna Jan 21, 2009
    I NEED MORE RAM FOR MY E MACHINE AND DONT KNOW WHAT KIND OR HOW TO INSTALL IT. CAN ANYONE HELP
    Sergeant:
    Champion:
  • 334 Answers
What model is your pc ill send u link to 1 gb ram chip ok easy to instal open side cover u see one that looks like pop new one in empyt slot ok
Posted on Oct 14, 2008
Yes, there is. You can find information about it here:
http://en.wikipedia.org/wiki/DDR_SDRAM
If you want real help, know your motherboard's brand & model so we could check what type of RAM it supports. If you can't find out, download and install speccy or aida64. It could give detailed report about the specs of your pc.
Hope this helps.
Jul 07, 2012 | ZT Group Cisnet PC Desktop
I have an acer aspire t180 desktop i have purchased a new ram and would like to install it, i have removed the side panel like told on here however i dont know where the ram needs to be placed as all is...
Installing RAM is very easy. First of all make sure the RAM you bought is compatible with your system. If you not sure visit crucial web site and scan your system with their program.
After that please watch this video
Visit Somdtech.co.uk
Sep 04, 2010 | Computers & Internet
Upgrading my compaq evo d51s
A ram upgrade could help, however you may need to think about upgrading your CPU also. First check if you can upgrade your CPU. Your best option may be to upgrade to a new computer altogether.
May 07, 2009 | Compaq Evo D500 PC Desktop
Memory hardware problem
What kind of RAM did you install? If the RAM should match the speed-limits of your motherboard. So if your RAM speed is, say, 667MHz and your board will only use 400MHz or 533MHz, you will need to get the correct speed. Check your user guide for the correct specs of memory for your particular model systems. Good Luck.
Feb 02, 2009 | E-Machines T5082 PC Desktop
E michine pc where is the C mos battery?
Have you checked the manufacturer's we site?
Oct 31, 2008 | E-Machines eMachines T3830 PC Desktop
How to install ram
Most E-machines have shared video memory. to increase the amount, enter the set-up utility before windows boots and change the amount to the max.48cb029.jpg
the blue or the black on the left with white tabs are where the ram is installed. if you go to crucial.com and enter the e-machines model # etc it will tell you what ram is compatible and what the max ram amount is.
Oct 14, 2008 | E-Machines eMachines Desktop PC
How to chang a video system
This is how to replace RAM in a PC. It just takes a few simple steps to do this, it is really not that hard. You can trust me since I have an a+ certification in computer hardware and software. I know what I am doing, I am an expert.
1. First of all, you need to shut off your computer. To do this press the power button on the front of the computer after you have shut it down from Start> Shutdown on your start menu.
2. Unplug the power cord from your computer. This is the big black/white/grey plug that plugs into the power supply on the back of your PC.
3. Unplug the rest of the wires from the back of the computer.
4. Find a sturdy flat surface on which to work on.
5. Unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
6. Open your computer up by taking the side panel off, or sliding the cover off. It might be difficult but it will come off if you have taken all the screws out.
5. Now before touching anything inside, it is a good idea to hook up to an anti-static wrist strap. If you dont have an anti-static wrist strap, just touch the side of the computer where it is metal to deshock yourself. Then when you touch the inner components you wont risk damaging any of them.
7. Find the RAM, it should be a 4 inch card sticking out horizontally on the motherboard.
8. Once you find the RAM, find the clips holding it in on either end of the ram, hold your thumb over both ends of the clips and firmly press down on the clips. They should pop the ram out.
9. Remove the RAM.
10. Now that you've removed the ram, the next step is to reinsert some new ram into your ram slots. To do this keep the clips on both sides open, and slide the ram into the slot if it doesnt want to go in you might have it going in backwards so try both ways until you get a good fit. Make sure the ram is not lopsided when its clamped down or it will not work.
Thank you, happy computing!
Kevin
My computer is about 5 years old. I bought a pny 4gb flash drive to save some info on. Someone told me that the computer does'nt reconize what kind device it is. I needed to know what kind of driver or...
If it is XP , usually it will detect the flash drive. If it is win98 you may require a driver for the flash drive.Give the model number of your drive. I Will try to help you to get the driver if your system is windows98/2000
May 09, 2008 | Computers & Internet
Ram
you could POTENTIALLY hook up an external hard drive and go into properties and change the Page File usage, however I would not recommend it. Page file acts like ram but it is extremely slow and usually not needed anyway
Apr 28, 2008 | Dell Dimension 4600 PC Desktop
E-Machines eMachines Desktop PC Logo
288 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
