DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Hi there. To enable your Samsung DVD player to work on your Sony Plasma, you will need two things:
1. The Power cable for the DVD player 2. The Audio(Red and White) and Video(Yellow) cables that should have been provided when the DVD player was bought. If ever these cables are not available, you may buy these at any Hyper Market such as Wal-Mart or a technology store such as Best Buy. These are called Composite Video and Audio Cables.
If you have the previous cables, connect the 3 Audio/Video cables to the back of the Plasma TV, it should contain the appropriate ports. Yellow cable(Video) for the Yellow port. White and Red for the Audio Left(L) and Right(R) ports. Then connect your power, turn the DVD on and switch from TV to other input which should display the Samsung Logo.
You connect up a DVD to a TV via the Audio Visual leads, they go into the Red White, the Audio, & Yellow, the composite Video. In & Out. They wire color to color. Then you select AV on the TV. & press Play on DVD.
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
DVD players do not connect using regular cable connections Your flat screen TV should have separate Audio and Video connections. These are the connections that you should use to connect your VCR and DVD player. If you have a combo unit, that is a single unit that has both DVD and VHS in one box, you might be able to get your VCR to work on the cable connection. However your DVD will not be able to work as the cable connection doesn't allow enough information to pass through. If you go to your local Audio Video store and tell them what you want to connect they should have the cables you need for less than $10.00. Good luck.
Yes. They are essentially Similar to any other 120 Watt Surround System for Home Entertainment. The Fact is, the only major difference is that the connections are different. On The PC it uses Stereo Standard Outputs. On Your DVD Player, It Will most Likely require an adapter to RCA (red/white -usually- Audio Cables). It just depends on your DVD Player. Have Fun!..... :)
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV: cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback; click below for more information in hooking up:
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable.
Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow)
Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red.
At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks.
I hope this helps.
First check Color code
Yellow is for Video Red is for Audio Right Speaker White is for Left Speak.
Do you see rear pannel of the DVD there is Socket
Connect Yellow Cable to Video Out on the Dvd other end of the Cable to Video In on TV.
Connect Red Cable to Audio Out on the DVD other end of the cable to Audio In on TV.
Connect White Cable to Audio Out on the DVD other end of the Cable to Audio In on TV.
Turn on TV as well as DVD Player.
ON tv remote do you seee buttons as TV/AV. AV, Aux, Video, Input, or Game, Pree any one of these Buttons, You should be able to get Picture.
what is the problem that you are having? what is the model number of your dvd player and your tv?
